查看: 449|回复: 46
alcohol in the truck?
 楼主| 发表于 2019-8-19 07:55:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"is it illegal? do any of you keep beer/liquor in your fridge for after your shift?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-19 10:03:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I get the want to help newbies out but some things should not be passed on through public online stuff. \n\nI get most every one on here is anonymous but it will bring an eye to what goes on as a whole! \n\nThere is some stuff I’m not ok with hiding under the brotherhood and then there is other stuff that only the brotherhood needs to know. ","replyToPid":0}
回复 支持 7 反对 2
发表于 2019-8-19 08:02:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nope. It is illegal to have in cab or fridge. So I park go and buy a couple watch tv down them and get rid of the evidence. But do whatever you want to it’s your truck. ","replyToPid":0}
回复 支持 8 反对 1
发表于 2019-8-19 09:46:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"loose lips sink ships no? why post that online?","replyToPid":0}
回复 支持 8 反对 0
发表于 2019-8-19 09:52:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I smell a rat or some pork...","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-8-19 08:59:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yea it’s best not to have that on you! If the wrong person finds it that can mean big trouble ","replyToPid":0}
发表于 2019-8-19 09:11:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s a 24 hour out of service ticket if you have it in your truck. ","replyToPid":0}
回复 支持 3 反对 2
发表于 2019-8-19 11:03:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"No it’s not illegal, I keep a 5th of Tito’s, a joint and some chicken fingers in my fridge, right next to the peace maker Clint Eastwood ","replyToPid":0}
发表于 2019-8-19 09:06:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bigt is absolutely correct. The law states that if you are found in possession of any alcohol beverage while you are in control of a commercial motor vehicle it is a 24 hour out of service ticket. Well the law defines having control of a commercial motor vehicle as being anywhere upon that vehicle. \n\nSo technically to do like I do. when I stop I go buy it and sit and watch tv and drink it then throw away the evidence is illegal.\n\nOn the other hand if there is a bar close and you walk over and have a few then go back to your truck even if you’re what could be classified as drunk it is legal. As long as you have more than 4 hours before you go to on duty status. ","replyToPid":0}
发表于 2019-8-19 19:50:53 来自手机 | 显示全部楼层
764757 发表于 2019-08-19 02:40:04 technically you're not even supposed to have mouthwash that contains alcohol in it in your truck,so yeah alcohol in the truck is illegal
","text":"Wow! Definitely wasn’t aware the rule also included mouthwash 🤦🏽‍♀️. That’s kinda crazy. ","replyToPid":184538}
发表于 2019-8-20 12:16:34 来自手机 | 显示全部楼层
610123 发表于 2019-08-19 15:56:20 You cannot while loaded but if off duty or doing pc you can have it in the truck.
","text":"wrong.  If alchohol is anywhere on your truck then you are busted.  Does not matter if on duty or not.","replyToPid":185040}
 楼主| 发表于 2019-8-19 08:40:31 来自手机 | 显示全部楼层
771835 发表于 2019-08-19 00:02:08 Nope. It is illegal to have in cab or fridge. So I park go and buy a couple watch tv down them and get rid of the evidence. But do whatever you want to it’s your truck.
","text":"good to know. thanks","replyToPid":184346}
发表于 2019-8-19 09:51:06 来自手机 | 显示全部楼层
197387 发表于 2019-08-19 01:46:11 loose lips sink ships no? why post that online?
","text":"Exactly","replyToPid":184454}
 楼主| 发表于 2019-8-19 09:53:28 来自手机 | 显示全部楼层
505487 发表于 2019-08-19 01:52:14 I smell a rat or some pork...
","text":"lol","replyToPid":184462}
GMT+8, 2026-2-9 12:50 , Processed in 0.085506 second(s), 24 queries .
