查看: 309|回复: 34
Driving with sprained ankle?
 楼主| 发表于 2019-8-19 05:36:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"Have you done it before?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-19 07:27:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"After knee surgery that’s crazy I did in a cast once it was teaming with a friend automatic freight shaker he was quite impressive of my one arm backing skills. It’s amazing how well our mind and body can adjust to difficulty situations ","replyToPid":0}
发表于 2019-8-19 05:46:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've seen a person driving a truck after a knee surgery to the left knee. It's not easy, luckily the truck has automatic transmission, unfortunately it also has a clutch....\nHe used the trailer brake a lot and when it was time to stop I think he put it in neutral at a very low speed.","replyToPid":0}
发表于 2019-8-19 07:59:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"no I'm too thin","replyToPid":0}
发表于 2019-8-19 09:55:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I drove with a walking cast before hurt like hell don’t recommend it. ","replyToPid":0}
发表于 2019-8-19 09:56:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"I sprained my wrist for being a Master Baiter 🤣😂🤣💪","replyToPid":0}
发表于 2019-8-19 10:10:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why do it? Are you that money hungry? Take a break! Stop being a slave!","replyToPid":0}
发表于 2019-8-19 10:10:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why do it? Are you that money hungry? Take a break! ","replyToPid":0}
发表于 2019-8-19 10:24:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"It was while he was doing his physical therapy and still had to wear a brace. It wasn't easy though because he still had to use the clutch every now and then.... ","replyToPid":0}
发表于 2019-8-19 10:31:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was in Texas loading melons and severely rolled my ankle and had to go to the hospital and get a boot put on it in order to be able to use the clutch to get back home to Iowa,I think that was the worst pain I've ever experienced out here","replyToPid":0}
GMT+8, 2026-4-18 06:37 , Processed in 0.115786 second(s), 24 queries .
