查看: 185|回复: 18
Fuel islands aren’t vacation destinations
 楼主| 发表于 2019-8-19 00:25:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’ve noticed a trend over the last couple years.. drivers have zero fuel island etiquette. I just don’t understand drivers these days. Why would you be so rude as to not pull forward after fueling? Or even worse taking your 30 minute break on the pump? Have some respect l, all of our time is valuable and limited..  stop and think about someone besides yourself once in a while!!!! \nIf I see you doing this I will let you know what a rude POS you are!","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-19 01:32:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"then why do we call it an island?  sounds vacationish to me.","replyToPid":0}
回复 支持 9 反对 0
发表于 2019-8-19 01:44:03 来自手机 | 显示全部楼层
558928 发表于 2019-08-18 17:32:24 then why do we call it an island?  sounds vacationish to me.
","text":"Like Alcatraz?","replyToPid":183960}
回复 支持 5 反对 1
发表于 2019-8-19 01:45:16 来自手机 | 显示全部楼层
","text":"🤣😂🤣🤣🤣😂 LMFAO","replyToPid":183960}
发表于 2019-8-19 01:44:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"lol true.","replyToPid":183965}
发表于 2019-8-19 04:26:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"You be polite pull forward go inside to use bathroom and get food. Next thing you know they calling you on the pa to move your truck. \n\nThis has happened to many times to me so I stopped pulling forward. ","replyToPid":0}
发表于 2019-8-19 01:19:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Because they are pieces of sh;t. ","replyToPid":0}
发表于 2019-8-19 00:54:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"No you won’t asshole ","replyToPid":0}
发表于 2019-8-19 06:40:40 来自手机 | 显示全部楼层
542330 发表于 2019-08-18 20:26:49 You be polite pull forward go inside to use bathroom and get food. Next thing you know they calling you on the pa to move your truck. \n\nThis has happened to many times to me so I stopped pulling forward.
","text":"you could ignore the PA","replyToPid":184101}
发表于 2019-8-19 06:30:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"it doesn't matter if you stay at the pump or pull forward. someone is going to bit *ch.","replyToPid":0}
发表于 2019-8-19 03:21:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I have to take an emergency 💩 while I'm in the fuel Island is that considered bad trip planning?","replyToPid":0}
发表于 2019-8-19 02:49:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was at oasis I Al on Wednesday and all 5 fuel islands were occupied by no one getting fuel. After 10 min I had a blow up and cleared out all 5 lanes.  It was hilarious.  The cashiers were rolling. ","replyToPid":0}
GMT+8, 2026-2-9 03:14 , Processed in 0.095721 second(s), 24 queries .
