查看: 396|回复: 11
I'm 2000 miles from home...my question is can I drive this on the road without have DOT stop me?
 楼主| 发表于 2019-8-18 05:59:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true}
发表于 2019-8-18 06:36:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes.... unless you come across a 🍆 officer. ","replyToPid":0}
回复 支持 9 反对 1
发表于 2019-8-18 06:23:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"YES I SEEN MUCH MUCH WORSE\nU WILL BE FINE","replyToPid":0}
回复 支持 5 反对 1
发表于 2019-8-18 06:10:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"The bumper is not an issue, but the metal protruding towards the front might be a problem ...","replyToPid":0}
发表于 2019-8-18 08:49:03 来自手机 | 显示全部楼层
602062 发表于 2019-08-18 00:35:05 That's what my bumper looked like when a tanker driver didn't bother to check his mirror when he made a turn. From now on whenever I park on the last spot I place a warning triangle by the front corner of the truck.
","text":"They’ll hit that too 💥🚛","replyToPid":183446}
发表于 2019-8-18 06:58:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"get the tube for the bumper pushed back and make sure the lights work and send it. I've seen alot worse on the road.","replyToPid":0}
发表于 2019-8-18 06:46:44 来自手机 | 显示全部楼层
742608 发表于 2019-08-17 22:36:02 Yes.... unless you come across a 🍆 officer.
","text":"if you're white then you have absolutely nothing to worry about","replyToPid":183332}
发表于 2019-8-18 08:35:05 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"That's what my bumper looked like when a tanker driver didn't bother to check his mirror when he made a turn. From now on whenever I park on the last spot I place a warning triangle by the front corner of the truck."}
发表于 2019-8-18 09:00:34 来自手机 | 显示全部楼层
682867 发表于 2019-08-18 00:49:03 They’ll hit that too 💥🚛
","text":"yeah last spot no good","replyToPid":183467}
发表于 2019-8-18 07:28:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes u can ","replyToPid":0}
发表于 2019-8-18 07:30:52 来自手机 | 显示全部楼层
","text":"😂🤣😂😂🤣","replyToPid":183332}
GMT+8, 2026-4-18 02:52 , Processed in 0.096376 second(s), 24 queries .
