查看: 232|回复: 14
Question
 楼主| 发表于 2019-8-18 03:00:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"I need some advice I was just given a brand new 750 watt power inverter with a 1500 peak wattage will it run my refrigerator and microwave in my truck with no problem or do I need to buy a bigger one ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-18 03:58:45 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you wanna run a microwave you should get an inverter that’s at least 1200 watt. "}
发表于 2019-8-18 07:46:29 来自手机 | 显示全部楼层
688068 发表于 2019-08-17 20:04:48 your fridge and TV won't be using that much wattage so you can use your microwave with them both plugged in.  Just a tip: keep your fridge full it will run more efficiently and run less.
","text":"Out of curiosity, how does a full fridge runs more efficiently than empty one?","replyToPid":183149}
发表于 2019-8-18 08:46:57 来自手机 | 显示全部楼层
599477 发表于 2019-08-17 19:58:45 If you wanna run a microwave you should get an inverter that’s at least 1200 watt.
","text":"agreed. mine is 1200. I have to idle the truck to use my 700 watt microwave for more than 1 minute.","replyToPid":183133}
发表于 2019-8-18 04:03:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes, it will, but check that wattage for your microwave.","replyToPid":0}
发表于 2019-8-18 03:08:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Absolutely ","replyToPid":0}
发表于 2019-8-18 03:18:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"check the wattage on your appliances and purchase adequate wattage inverter.","replyToPid":0}
 楼主| 发表于 2019-8-18 03:33:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you I greatly appreciate it and I will also check the wattage on my appliances now if I wanted to run a tv would I have to unhook the fridge or microwave from the inverter or would they all be ok plugged it in at the same time ","replyToPid":0}
发表于 2019-8-18 03:42:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"probably going to need a bigger one","replyToPid":0}
发表于 2019-8-18 04:04:48 来自手机 | 显示全部楼层
781531 发表于 2019-08-17 19:33:20 Thank you I greatly appreciate it and I will also check the wattage on my appliances now if I wanted to run a tv would I have to unhook the fridge or microwave from the inverter or would they all be ok plugged it in at the same time
","text":"your fridge and TV won't be using that much wattage so you can use your microwave with them both plugged in.  Just a tip: keep your fridge full it will run more efficiently and run less.","replyToPid":183117}
 楼主| 发表于 2019-8-18 04:09:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you for all y’all help I appreciate any advice just got my cdls getting ready to roll out wanted to make sure my truck was set up good ","replyToPid":0}
发表于 2019-8-18 05:52:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get a pure wine wive inverter if that one isn’t. Modified sine wave inverters are know to mess up certain appliances or reduce the life of them. Really shouldn’t need an inverter of more than 1500 if you won’t use it much. 2000 to be safe though","replyToPid":0}
GMT+8, 2026-4-18 12:28 , Processed in 0.093174 second(s), 24 queries .
