查看: 174|回复: 4
I added the straps, shipper is sealing the trailer but double stacked the last pallet. Why?
 楼主| 发表于 2019-8-17 02:51:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":853.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":true}
发表于 2019-8-17 05:16:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would strap around that pallet back to the same wall","replyToPid":0}
发表于 2019-8-17 05:01:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"gotta make it fit and maybe spreading the weight out like they are supposed too.","replyToPid":0}
发表于 2019-8-17 06:17:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"so the bottom pallet starts crushing at the bottom and you can have the fun of trying to get it out without tipping it over. when I was pulling reefer id always make them split pallets like that up. at least you have etracs though I'd go around it like someone said previously.","replyToPid":0}
发表于 2019-8-19 02:48:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"next time use a condom","replyToPid":0}
GMT+8, 2026-4-18 03:52 , Processed in 0.100163 second(s), 24 queries .
