查看: 277|回复: 11
What a man
 楼主| 发表于 2019-8-17 00:37:44 来自手机 | 显示全部楼层 |阅读模式
{"text":"The first load of my pal after leaving his trainer, was in too much of a hurry and forgot to check trailer height before coupling. Thought you all might get a kick out of it.\n","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":853.0,\"name\":\"\",\"url\":\"\",\"width\":640.0}]","canComment":true}
发表于 2019-8-18 08:44:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"some of the larger companies trucks don't a dump valve for the truck. hell your lucky if the 5th wheel slides","replyToPid":0}
发表于 2019-8-17 14:54:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"drop the airbags tilt the fifth wheel forward and ease out","replyToPid":0}
发表于 2019-8-17 13:38:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Man his arms are gonna be tired. ","replyToPid":0}
发表于 2019-8-17 12:23:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh that I feel for him. I’ve been there because of a high dropped trailer. Talk about a workout. Lol","replyToPid":0}
发表于 2019-8-17 00:39:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤦🏻‍♀️","replyToPid":0}
发表于 2019-8-17 12:49:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put a little bit tape on it he’ll be ok. ","replyToPid":0}
发表于 2019-8-17 18:41:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"had this happen to me a couple times.. had to find a nearby branch to leverage fifth wheel down so I can drive out 🤣","replyToPid":0}
发表于 2019-8-18 02:33:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"dump the air out and tilt the 5th and pull ahead oh yea put a coffee cup one the back side of the 5th wheel.to keep it tilted. it works believe me. I use to hook into trailers that guys use to have ro crank up way to much. had an old time teach me that 20yrs ago","replyToPid":0}
发表于 2019-8-18 03:02:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Stevens actually trains drivers to crank trailers too high. They don't want the air dumped out of the tractor bags when dropping a trailer. They tell you to crank until you start lifting the tractor 😒","replyToPid":0}
发表于 2019-8-18 08:42:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always carry a crow bar and a couple of blocks. 4x4 and 2x2.  \n when I back up to a trailer . I try to not back all the way .. stop just about where my drive tires are just under the front.","replyToPid":0}
GMT+8, 2026-4-18 21:45 , Processed in 0.084427 second(s), 24 queries .
