查看: 464|回复: 5
TMC rest area parks diagonal taking 3 spots and leaves his *** in the isle too, thanks *******
 楼主| 发表于 2019-5-17 21:31:11 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1000.0 ,\"name\":\"\",\"url\":\" \",\"width\":750.0}]","canComment":true}
发表于 2019-6-28 02:25:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"While there are some exceptions to the rule, most skateboarders can't back worth a dang.","replyToPid":0}
回复 支持 3 反对 2
发表于 2019-7-29 01:21:32 来自手机 | 显示全部楼层
706634 发表于 2019-06-27 18:25:31 While there are some exceptions to the rule, most skateboarders can't back worth a dang.
","text":"Funny, I can say the same for all the van drivers out there too. Your sweeping generalizations show your lack of experience.","replyToPid":133095}
发表于 2019-7-10 08:39:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"True, but that’s a pull-through.  \n\nIn some states you can call the cops , they’ll come by and... remonstrate with the jerk ","replyToPid":0}
发表于 2019-7-29 01:19:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pull his pin and/or loosen several valve stem cores.","replyToPid":0}
发表于 2019-7-29 14:29:49 来自手机 | 显示全部楼层
452168 发表于 2019-07-28 17:21:32 Funny, I can say the same for all the van drivers out there too. Your sweeping generalizations show your lack of experience.
","text":"Sure does. Pretty much any driver that’s been at it for 2+ years can back it in from the highway. Of coarse there are exceptions. ","replyToPid":158842}
GMT+8, 2026-4-17 23:50 , Processed in 0.101369 second(s), 24 queries .
