查看: 400|回复: 27
Advice on staying awake???
 楼主| 发表于 2019-8-16 03:55:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’ve been driving for a few years now and never had any issues. Lately I seem to struggle staying awake after 2-3hrs of driving. I’m getting about 7-9hrs of sleep. I’m trying to cut back on energy drinks.\n","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-16 04:38:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take a 30 minute nap. Believe me it helps. You might not even fully get to sleep but it does help.\n","replyToPid":0}
回复 支持 9 反对 0
发表于 2019-8-16 04:39:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also, I had the same issue starting out. You gotta watch what you eat and get more exercise. It helps a ton. Also, you said you are cutting back on energy drinks? Depending on how much you used to drink those, your body is likely going through mild withdrawal symptoms\n","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-8-16 04:40:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do not consume caffeine keep your tolerance low so that it can work when absolutely necessary. I find having any sort of caffeine tolerance makes me tired without it, even when I have it. But in a weird way that doesn’t let me sleep when I’m in bed trying to get rest. This way though when I need it it really gives me that kick.\n","replyToPid":0}
回复 支持 5 反对 1
发表于 2019-8-16 04:39:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I dont know what your daily eating and workout habits are. But try to eat better and make healthier options and go for a walk or something before you sleep or when you wake up. You'll feel better, sleep better and have more energy. If your OTR that may be hard but even small changes will be beneficial.\n","replyToPid":0}
发表于 2019-8-16 04:40:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like you get bored while driving after a couple hours. \n\nTalk on the phone. Find audio books that keep you interested. I have an audible account 2 books a month does wonders. ","replyToPid":0}
发表于 2019-8-16 04:40:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can do it my pal. Take care of yourself","replyToPid":0}
发表于 2019-8-16 04:42:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you sleeping consistent hours or are you working different shifts? Because I know that despite how common it is but trucking to do so sleeping at different times will mess with your circadian rythym so 7-9 hours at different times might not be the same quality of sleep\n","replyToPid":0}
发表于 2019-8-16 06:22:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"consistent start time and if you really need to a 20-30 min power nap works wonders.","replyToPid":0}
发表于 2019-8-16 14:09:52 来自手机 | 显示全部楼层
773586 发表于 2019-08-16 01:17:17 Stop at a rest stop, get out your truck and do a post trip inspection to get the blood pumping.
","text":"Go through the scale and get pulled in. \n\nThat gets blood moving real fast","replyToPid":181444}
发表于 2019-8-16 09:10:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put a rock in your boot. Put the boot on and when you start getting drowsy SLAM your foot on the floor. Guaranteed to wake yourself up. Lmao. Just kidding. Crack a window n get fresh air in the cab or keep a wet towel with you n wipe your face n eyes. It's refreshing. If nothing works then stop n take a nap. ","replyToPid":0}
发表于 2019-8-16 04:40:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"we need to be strong in this work, and we need sleep!","replyToPid":0}
发表于 2019-8-16 04:41:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I found it really easy to stay awake during the day taking a 30min-1 hour break getting out of the truck whenever I needed to, etc. night shifts are brutal when it comes to this so much so that staying awake during that day became easier\n","replyToPid":0}
GMT+8, 2026-4-18 03:54 , Processed in 0.100005 second(s), 24 queries .
