查看: 317|回复: 15
RV
 楼主| 发表于 2019-8-14 09:19:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey all,\n\nI downloaded this app so I wouldn’t run into (too many) road nightmares. Also have a paper trucking atlas. Will hopefully be worth the $20 it cost. I’m not a trucker but I’m in a beast of an RV with a sedan in tow. I’ve taken extended road trips in regular cars, and I’ve driven large military vehicles before, but any advice for a digital nomad like me? Or am I in the wrong place and I should F off?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-14 10:27:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"You're good here,in my humble opinion","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-8-14 11:30:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"have fun. your in an RV enjoy it. a cb might help. I'll trade ya. LoL","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-8-15 01:20:25 来自手机 | 显示全部楼层
发表于 2019-8-14 22:53:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"interstate is good. parkway is bad. and if the clearance looks too low and there's no height maker pull over and wait for a larger truck to go thru","replyToPid":0}
发表于 2019-8-14 15:01:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Welcome!! Only advice I can give is... when in doubt, check the atlas. There will be road closures, detours, unforeseen circumstances, etc. Sometimes, when they are extremely recent, the gps may not be aware & try to send you through it. The atlas is your best friend. 💯 ","replyToPid":0}
发表于 2019-8-16 06:23:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"if this becomes rv path I am out.","replyToPid":0}
发表于 2019-8-17 09:17:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"f off 😂😂","replyToPid":0}
发表于 2019-8-15 19:24:48 来自手机 | 显示全部楼层
{"replyToPid":179684,"replyTo":"
197387 发表于 2019-08-14 14:53:52 interstate is good. parkway is bad. and if the clearance looks too low and there's no height maker pull over and wait for a larger truck to go thru
","text":"I don’t know why but this just seems like some good advice that a swift mentor a tell his student. "}
发表于 2019-8-18 05:02:32 来自手机 | 显示全部楼层
630372 发表于 2019-08-17 19:29:03 Swift drivers are the best on the road.
","text":"Yeah the best at putting a 73 ft, 80000 lbs, truck some where it don’t belong ","replyToPid":183113}
发表于 2019-8-18 03:29:03 来自手机 | 显示全部楼层
762947 发表于 2019-08-15 11:24:48 I don’t know why but this just seems like some good advice that a swift mentor a tell his student.
","text":"Swift drivers are the best on the road. ","replyToPid":180644}
发表于 2019-8-14 19:58:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good advice from all","replyToPid":0}
 楼主| 发表于 2019-8-15 00:34:55 来自手机 | 显示全部楼层
625878 发表于 2019-08-14 02:34:37 You are in a good forum, we will help when possible.
","text":"I appreciate it!","replyToPid":179213}
 楼主| 发表于 2019-8-15 00:36:17 来自手机 | 显示全部楼层
742608 发表于 2019-08-14 07:01:30 Welcome!! Only advice I can give is... when in doubt, check the atlas. There will be road closures, detours, unforeseen circumstances, etc. Sometimes, when they are extremely recent, the gps may not be aware & try to send you through it. The atlas is your best friend. 💯
","text":"You know I used to be great at land nav, but put me behind a wheel and it’s a whole different story! I gotta crack that atlas for sure ","replyToPid":179416}
GMT+8, 2026-4-18 03:54 , Processed in 0.770620 second(s), 24 queries .
