查看: 152|回复: 0
2011 Cascadia front end thunk noise when loaded?
 楼主| 发表于 2019-1-24 17:40:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"Have a 2011 cascadia. Thunk noise happens when loaded. Doesn't always happen but when it does it from braking or when turning on uneven ground. Also can feel a sort of grinding noise at times at very low speeds under 5mph.","pics":"[]","canComment":true}
GMT+8, 2026-4-17 07:53 , Processed in 0.066932 second(s), 23 queries .
