查看: 128|回复: 12
drinking and trucking
 楼主| 发表于 2019-8-13 09:08:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"why do people do it!? It’s already bad enough when drinking alcohol in a normal car is like. But in a semi its like 10x worse!!","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-13 12:19:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drinking and driving is never ok and is even worse in a rig. Although if you have a few drinks on your 10 what is wrong with that? So every other industry can get out of work go home and have a few beers but because we are truckers and live in our trucks we should not get the same pleasures? ","replyToPid":0}
发表于 2019-8-14 00:16:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cause we ed is so much better?!","replyToPid":0}
 楼主| 发表于 2019-8-13 19:07:48 来自手机 | 显示全部楼层
103619 发表于 2019-08-13 05:51:48 I'm sorry if my rootbeer offended you. I'll switch to 7 up or Sprite
","text":"nuuu I meant like alcohol stuffs XD","replyToPid":178407}
发表于 2019-8-13 13:51:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm sorry if my rootbeer offended you. I'll switch to 7 up or Sprite","replyToPid":0}
发表于 2019-8-13 12:14:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"because people are stupid","replyToPid":0}
发表于 2019-8-13 12:17:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"Because it’s hot out and you have to stay hydrated.  ","replyToPid":0}
发表于 2019-8-13 09:52:56 来自手机 | 显示全部楼层
发表于 2019-8-13 09:10:26 来自手机 | 显示全部楼层
 楼主| 发表于 2019-8-13 19:07:18 来自手机 | 显示全部楼层
762947 发表于 2019-08-13 04:17:22 Because it’s hot out and you have to stay hydrated.
","text":"with alcohol?? cold water and soda does better XD","replyToPid":178363}
发表于 2019-8-14 00:16:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Cause weed is so much better?!","replyToPid":0}
GMT+8, 2026-2-8 18:51 , Processed in 0.053068 second(s), 24 queries .
