查看: 120|回复: 3
HOS question
 楼主| 发表于 2019-8-13 06:16:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can you do a post trip inspection if you're out of time on your 14 hour clock? My trainer said you can but you have to be on duty to do the inspection so that doesn't make sense.","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-8-13 09:53:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"OK I get it. I thought you could only be on duty 14 hours but the 14 hours just limits when you can drive. Thanks.","replyToPid":0}
发表于 2019-8-13 07:00:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes you have to be on duty. \n\nThe way hours work is you can be on duty all day all week. You just can’t drive. \n\nThe only way to be in violation is on drive line. You can be on duty for 18 hours. You can’t drive till you take your 10hr break. ","replyToPid":0}
发表于 2019-8-17 00:25:52 来自手机 | 显示全部楼层
542330 发表于 2019-08-12 23:00:03 Yes you have to be on duty. \n\nThe way hours work is you can be on duty all day all week. You just can’t drive. \n\nThe only way to be in violation is on drive line. You can be on duty for 18 hours. You can’t drive till you take your 10hr break.
","text":"he is 100% correct","replyToPid":178049}
GMT+8, 2026-4-18 07:01 , Processed in 0.084344 second(s), 24 queries .
