查看: 477|回复: 17
Do you feel safe taking your 10 at a rest area with few trucks in it
 楼主| 发表于 2019-8-13 04:10:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"Or would you rather take your 10 in a major truckstop?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-13 07:41:10 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"The only way anyone could break into my trailer is  cutting a hole in it, and if they break into the truck, they'll be the ones dialing 911 if they make it out alive."}
回复 支持 7 反对 0
发表于 2019-8-13 07:31:32 来自手机 | 显示全部楼层
643146 发表于 2019-08-12 21:04:03 Personally I prefer to be as far away from other trucks as possible. It’s the trucks that attract the bad element. No fault of the drivers, just the way it is.
","text":"I agree. I prefer rest areas and small no name truck stops over all of the large chain truck stops. Put a padlock on your trailer doors and usually if you do not mess with other they will not mess with you either","replyToPid":177899}
回复 支持 6 反对 0
发表于 2019-8-13 08:10:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"rarely do I use truckstop. only for fuel food or showers. rest areas are my choice. have been for 10 plus years...","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-8-13 08:48:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Quiet rest areas are my favourite.  It's nice to get away from the noise and industrial ambiance we live in all day.","replyToPid":0}
发表于 2019-8-13 04:18:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Honestly it doesn't matter to me. I have many items that can be used as protection and it's quite peaceful without the risk of weirdos running into the truck by accident.","replyToPid":0}
发表于 2019-8-13 08:37:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm more concerned with some crazy driver hitting my trailer than trying to get into my truck so I'll park in a area where that \"less\" likely to occur most of the time its not at a busy truck stop.","replyToPid":0}
发表于 2019-8-13 07:39:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't care about where I stop, I don't live my life in fear....","replyToPid":0}
发表于 2019-8-13 07:32:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always away from the truck stop. I like complete darkness. So I always try to find a country road away from everyone. ","replyToPid":0}
发表于 2019-8-13 08:35:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I feel safe anywhere..Seriously","replyToPid":0}
发表于 2019-8-13 08:23:04 来自手机 | 显示全部楼层
103619 发表于 2019-08-13 00:10:32 rarely do I use truckstop. only for fuel food or showers. rest areas are my choice. have been for 10 plus years...
","text":"same here. I need a very specific reason to park at a truckstop.","replyToPid":178135}
发表于 2019-8-13 05:04:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Personally I prefer to be as far away from other trucks as possible. It’s the trucks that attract the bad element. No fault of the drivers, just the way it is.","replyToPid":0}
GMT+8, 2026-4-18 01:04 , Processed in 0.082846 second(s), 24 queries .
