查看: 67|回复: 5
Is it true that smoking can cause bad judgement?
 楼主| 发表于 2019-8-13 01:41:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"Read an article online that most people who cause accidents are smokers. Do you believe it?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-13 11:09:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bad judgement causing smoking ","replyToPid":0}
发表于 2019-8-13 09:59:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Smoke what? Tobacco? Weed? If weed then yes. Delayed reaction time and reflex, which means you can't respond to someone swerving in front of you properly.","replyToPid":0}
发表于 2019-8-13 10:09:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends what they are smoking. be specific. could be crack, meth, weed, nicotine, freebase, heroine. so what was the article about?","replyToPid":0}
发表于 2019-8-13 10:10:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"dam had a great answer but truckers path has to review it. f^ck!ng tw@tw@ffles they are.","replyToPid":0}
发表于 2019-8-14 00:20:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"What are you smokin. \n\nThat satanic salad?","replyToPid":0}
GMT+8, 2026-2-8 17:20 , Processed in 0.055081 second(s), 24 queries .
