查看: 224|回复: 7
DOT officer on a close weight station
 楼主| 发表于 2019-8-13 01:39:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do they still inspect you?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-14 01:07:02 来自手机 | 显示全部楼层
103619 发表于 2019-08-13 15:02:26 better yet. use the rear side window if equipped.  and look out.. once in the front  \" the work area\" I was told your at possible to be on duty
","text":"That don’t seem right... If I’m logged in my eld, or log book as “off duty”, then I’m OFF DUTY... shouldn’t matter where I’m at in the truck...","replyToPid":178570}
发表于 2019-8-13 03:15:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dot can inspect you anytime or anywhere. I have seen them in rest areas inspecting trucks. \n\nJust know your rights. If you are off duty you are off duty. But if you take that off duty time in driver seat they can inspect you. ","replyToPid":0}
发表于 2019-8-13 23:41:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hide from them like they Jehovah witness and I don't even do anything wrong just don't want to be messed with 🤣","replyToPid":0}
发表于 2019-8-13 22:05:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"I learned the hard way when I first started. If they knock on your door YOU CAN LOOK OUTSIDE BUT DONT SIT ON THE DRIVERS SEAT. If your on off duty or sleeper birth they can’t inspect you. ","replyToPid":0}
发表于 2019-8-13 21:39:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"yep they can","replyToPid":0}
发表于 2019-8-13 21:40:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"except while your sleeping SB","replyToPid":0}
发表于 2019-8-13 23:02:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"better yet. use the rear side window if equipped.  and look out.. once in the front  \" the work area\" I was told your at possible to be on duty","replyToPid":0}
GMT+8, 2026-4-18 07:12 , Processed in 0.082645 second(s), 25 queries .
