查看: 97|回复: 3
Editing your HOS Logs
 楼主| 发表于 2019-8-13 01:31:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"What if you edit your logs? Can the DOT officers still see it?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-13 03:17:23 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Yes the eld flags it red on your log sheet and it’s a different color on details so it sticks out like a sore thumb. "}
发表于 2019-8-16 14:41:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends what system your on , it doesn't change color on the pedigree system , cant remember on the keep trucking but the the navstar or one thru Garmin didn't change either , 5rust me I checked because I've done a lot of editing lmao","replyToPid":0}
发表于 2019-8-25 19:49:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"all depends on what system you use. I use Maven ,it shows the dot only what it needs to know just like a paper log","replyToPid":0}
GMT+8, 2026-4-18 01:03 , Processed in 0.071604 second(s), 24 queries .
