查看: 259|回复: 19
GPS
 楼主| 发表于 2019-8-12 20:20:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"About to get in my own truck and I need a GPS. What is a great GPS to use ?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-12 22:21:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use your phone ","replyToPid":0}
发表于 2019-8-12 21:37:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"dam bruh your on steroids huh??","replyToPid":0}
发表于 2019-8-12 23:07:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is my opinion, the Ran McNally 740 the reason being is it holds a long charge it doesn't bounce off the mount as easily as the other tables and it seems to be easier to maintain the only thing people say is the screen it not big enough well to be honest the bigger the screen the more likely for the GPS to bounce off and break.","replyToPid":0}
发表于 2019-8-12 21:14:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin Dezl gps. Rand McNallys have bad power cords and worse tech support ","replyToPid":0}
发表于 2019-8-13 22:45:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy a map and pre plan your way, you’ll learn more about being out on the road than you do with a gps, like the real old school truckers. ","replyToPid":0}
 楼主| 发表于 2019-8-13 10:44:58 来自手机 | 显示全部楼层
505487 发表于 2019-08-12 20:16:39 I could tell how much you benching?
","text":"80 pounds","replyToPid":177767}
发表于 2019-8-12 22:47:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin is the best one stay far away from rand","replyToPid":0}
发表于 2019-8-13 07:05:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"atlas","replyToPid":0}
发表于 2019-8-12 21:28:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"rand McNally's and buy the map also","replyToPid":0}
发表于 2019-8-12 22:02:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hands down the Garmin truck one ","replyToPid":0}
发表于 2019-8-12 22:56:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Garmin 780 dezl","replyToPid":0}
 楼主| 发表于 2019-8-13 03:57:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Die slow","replyToPid":177196}
GMT+8, 2026-4-18 03:32 , Processed in 0.109716 second(s), 24 queries .
