查看: 98|回复: 4
ELD question
 楼主| 发表于 2019-8-12 04:34:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"If your teammate is in sleeper berth. Do you need to indicate that on your ELD? or can he just log off-duty?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-12 09:30:11 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Nope, has to be logged in as long as he’s in the truck. \nLegally anyone with a CDL, even if they aren’t going to drive, must be logged in if they’re in a CMV. "}
发表于 2019-8-15 21:06:04 来自手机 | 显示全部楼层
发表于 2019-8-15 21:03:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"actually yes in fact as a team its mandatory that u each log at least 8 hrs consecutive in the sleeper berth as part of your 10 hr break , this is per fmcsa and if u get stopped u will get fined heavily and be put out of service","replyToPid":0}
发表于 2019-8-15 21:13:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"some states like NY require sleeper bearth logged in order to get your required break even  as a solo driver and if u only go off duty they require proof of hotel stay ect but that's states making stricter policies that are over and beyond  for as a solo driver per fmcsa regulation 10 hr off duty is enough as a team its mandatory to log the sleeper or your 10hr doesn't count period","replyToPid":0}
GMT+8, 2026-4-16 14:14 , Processed in 0.090783 second(s), 24 queries .
