查看: 402|回复: 11
Looking for another job while still employed
 楼主| 发表于 2019-5-17 04:48:12 来自手机 | 显示全部楼层 |阅读模式
{"text":"If I go and apply to a different company, isn't my current job going to know?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-17 05:48:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you’re searching for another Job, it means you aren’t happy with your current one. So even if they do find out, Why would it matter? If anything your current job Should feel Shameful that you’re out job hunting. \nGotta do what makes you Happy. ","replyToPid":0}
发表于 2019-5-17 06:09:07 来自手机 | 显示全部楼层
681674 发表于 2019-05-16 21:48:54 If you’re searching for another Job, it means you aren’t happy with your current one. So even if they do find out, Why would it matter? If anything your current job Should feel Shameful that you’re out job hunting. \nGotta do what makes you Happy.
","text":"exactly","replyToPid":36629}
发表于 2019-5-17 06:22:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only if they call the reference #.\nSend in the application anyway.","replyToPid":0}
发表于 2019-5-17 05:35:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends if they have connections","replyToPid":0}
发表于 2019-5-17 07:56:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"When u put your last 10 years work history down, the job you are currently working for put “do not contact “. They won’t contact until you are signed onto them. ","replyToPid":0}
发表于 2019-5-17 05:40:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why are you so worried? LOL","replyToPid":0}
发表于 2019-5-17 05:57:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most likely not. How would they to where the chances are more likely than not?","replyToPid":0}
发表于 2019-5-17 06:19:11 来自手机 | 显示全部楼层
546477 发表于 2019-05-16 21:57:31 Most likely not. How would they to where the chances are more likely than not?
","text":"yup. you going to need to factor this one too","replyToPid":36646}
发表于 2019-5-17 06:29:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just Doug the same thing today. And I hope they call the company I'm leased to now.  ","replyToPid":0}
发表于 2019-5-17 06:41:29 来自手机 | 显示全部楼层
620848 发表于 2019-05-16 22:19:11 yup. you going to need to factor this one too
","text":"LMAO. Was in a hurry ","replyToPid":36678}
GMT+8, 2026-4-15 12:09 , Processed in 3.112013 second(s), 24 queries .
