查看: 352|回复: 10
Violating HOS
 楼主| 发表于 2019-8-10 06:37:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello, I'm curious what actually happens when you violate your HOS?  Does it just get stored on your AORBD for 8 days and that's it?\n\nI'm probably going to violate it tonight.  I've been waiting in the dock for 5 hours.  😫\n\nShould I just leave and tell them I'll come back in the morning?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-10 21:00:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Effective immediately, the Federal Motor Carrier Safety Administration will allow drivers to enter into personal conveyance status, whether the truck is loaded or not, to find the nearest safe parking or rest location after their hours of service are exhausted by a shipper/receiver or off-duty periods are interrupted by law enforcement.\n\n“The movement from a shipper or receiver to the nearest safe resting area may be identified as personal conveyance,” according to a notice from FMCSA, “regardless of whether the driver exhausted his or her hours of service, as long as the CMV is being moved solely to enable the driver to obtain the required rest at a safe location.”","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-8-10 07:31:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"For that situation you can use pc to closest safe spot to park and take your 10","replyToPid":0}
发表于 2019-8-10 07:30:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s stored for 7 years on the computer at your company. When dot comes and audits your company they go over driver logs for last 7 years issuing fines to driver and company for any violations. ","replyToPid":0}
发表于 2019-8-10 10:58:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Firing squad.","replyToPid":0}
发表于 2019-8-11 07:19:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"While I like that rule, it's basically giving a free pass for Shippers and Receivers to take as long as they want to load or unload.","replyToPid":0}
发表于 2019-8-11 12:43:03 来自手机 | 显示全部楼层
25377 发表于 2019-08-10 23:19:12 While I like that rule, it's basically giving a free pass for Shippers and Receivers to take as long as they want to load or unload.
","text":"Yes it does but they are been doing this for years alist now they give us a lil break on this nonsense matter. \nThey should let us drive 11 hrs on a 24 hr clock just like most of the other professionals do ( I meant not drivers). Construction workers do crazy hrs, Cooks and waitress pull some crazy shifts, Paramedics and firefighters also, it's just amazing how they try to control over us drivers so much⌚⌚⌚📋📋📋 I don't know what You fellow Brothers and sisters Drivers think about this?","replyToPid":175569}
发表于 2019-8-12 05:36:50 来自手机 | 显示全部楼层
","text":"Not really. Because they would lose if that company becomes known for taking a long time to load|unloaded. \nThere is many apps and ways to find out typical load|unload times before even considering working for that company.","replyToPid":175569}
 楼主| 发表于 2019-8-17 18:38:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for replies guys.I just read that we get two extra hours of PC to find rest stop,https://www.nj.com/politics/2019/08/trump-administration-wants-truckers-to-work-longer-hours-despite-safety-concerns.html\n\ntoo bad my PC button on aobrd does not work.. 🤣, I can select it but it never lets me hit ok","replyToPid":0}
发表于 2019-8-19 02:06:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"I get violated by Truckers I  even give Team discounts.","replyToPid":0}
GMT+8, 2026-4-18 12:29 , Processed in 0.085446 second(s), 24 queries .
