查看: 591|回复: 19
o/o question
 楼主| 发表于 2019-8-9 20:22:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"I'm buying a truck and already finished the hiring process for this company. they require a certificate from the dealer saying the truck is governed at 65. my question is can I get the certificate but then bypass the governed speed after a few weeks? or should I just be a wimp and drive 65 miles/hour ? thanks !","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-9 20:29:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Find a different company, if you own the truck you should determine what speed it’s set at.","replyToPid":0}
回复 支持 12 反对 3
发表于 2019-8-9 21:08:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"what he said. what are they paying you 70% of truck gross. companys like that are out to make money off of you and you just barely make a living. I own my truck and I am leased on to a company. I get there fuel card my eld is through them my trailer and commodity insurance is through them I register my own truck I do my own ifta and quarterly the only downside to it is every 4 months I have to get my truck and trailer inspected at which they pay the bill if it passes and every month I have to do a maintenance report. with their fuel card I have seen up to $0.60 off a gallon and for everything that they do they only take 12% of truck gross. so I would do a little more research find a different company that will benefit yourself not benefit them good luck","replyToPid":0}
回复 支持 4 反对 4
发表于 2019-8-10 01:04:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"mannnnnnn .... allllll yall with these questions and not quite ready to be a fake owner operator........ stop it people..... drive a company truck for years and years and years and years till you make these moves without asking any of these questions i keep seeing on this stupid trucker chatting place........ ","replyToPid":0}
回复 支持 2 反对 5
发表于 2019-8-9 20:36:24 来自手机 | 显示全部楼层
616194 发表于 2019-08-09 12:29:23 Find a different company, if you own the truck you should determine what speed it’s set at.
","text":"My thoughts exactly Gizzard","replyToPid":173924}
回复 支持 3 反对 3
 楼主| 发表于 2019-8-10 02:33:09 来自手机 | 显示全部楼层
599477 发表于 2019-08-09 17:08:15 You definitely can! Just don’t ever let them know you changed it 😁
","text":"what about safety department, wont they see how much you speed through the eld? or did I read that wrong online somewhere","replyToPid":174206}
回复 支持 1 反对 4
发表于 2019-8-10 05:19:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also, depending on your eld and company, you can go in the device info and see what they consider your overspeed and excess speed. Typically they’ll only get alerted if you go over those. And typically the overspeed is based off of the pedal. But if you set cruise control to go over that limit.... 😉","replyToPid":0}
回复 支持 2 反对 3
发表于 2019-8-9 21:51:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its your truck, if u get a speeding ticket u have to pay not then. ","replyToPid":0}
回复 支持 1 反对 4
发表于 2019-8-25 20:19:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"find a better company. the one your looking at let's the insurance company run them. why be an o/o if you're going to let a company tell you how bo run","replyToPid":0}
回复 支持 1 反对 3
发表于 2019-8-10 12:22:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"I wouldn’t work for a company that tells me what I can and can’t do to my truck... 🖕🏻them","replyToPid":0}
回复 支持 1 反对 3
 楼主| 发表于 2019-8-10 08:16:46 来自手机 | 显示全部楼层
662769 发表于 2019-08-09 21:24:04 I'd tell that company to kiss my dìck
","text":"I think it's too soon to do that. maybe couple weeks after I start my runs ","replyToPid":174472}
回复 支持 0 反对 4
发表于 2019-8-9 21:58:11 来自手机 | 显示全部楼层
","text":"agreed👍","replyToPid":173924}
回复 支持 0 反对 3
发表于 2019-8-9 22:13:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"The magic question is, who paying for insurance them or you?  ","replyToPid":0}
回复 支持 0 反对 4
发表于 2019-8-10 01:08:15 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"You definitely can! Just don’t ever let them know you changed it 😁"}
回复 支持 1 反对 3
 楼主| 发表于 2019-8-10 02:32:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"they'll be paying majority of it. I pay $600 a month for insurance","replyToPid":0}
回复 支持 0 反对 4
GMT+8, 2026-4-15 14:09 , Processed in 0.141862 second(s), 24 queries .
