查看: 272|回复: 13
is it a major or minor defect?
 楼主| 发表于 2019-8-9 02:34:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true}
发表于 2019-8-9 03:33:56 来自手机 | 显示全部楼层
发表于 2019-8-9 10:05:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends on your company's tire program. Schneider would say, it still has good tread on it at 4/32. CR England would say, it ain't bald. Swift would say, replace it with a steer tire. Knight would say, use it as a spare.","replyToPid":0}
发表于 2019-8-9 10:33:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Major ..side wall is destroyed.","replyToPid":0}
发表于 2019-8-9 10:21:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’d say it’s fûcked. ","replyToPid":0}
发表于 2019-8-9 11:02:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Heats up. Pressure rises. Blows out while a car is passing. Smashes out their window. Troop comes to make a report. Yadda yadda","replyToPid":0}
发表于 2019-8-9 10:59:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s what happens when you run over curbs ","replyToPid":0}
发表于 2019-8-9 10:08:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'd say shove match sticks in it and melt it enough to make the slash dissapear drop off the trailer at a shipper burry it in the back somewhere and forget about it.","replyToPid":0}
发表于 2019-8-9 10:08:55 来自手机 | 显示全部楼层
662769 发表于 2019-08-08 19:33:56 All I see is a blàck crack or a Michelle Obama.
","text":"aka big Mike","replyToPid":172968}
 楼主| 发表于 2019-8-9 10:47:34 来自手机 | 显示全部楼层
635728 发表于 2019-08-09 02:05:02 depends on your company's tire program. Schneider would say, it still has good tread on it at 4/32. CR England would say, it ain't bald. Swift would say, replace it with a steer tire. Knight would say, use it as a spare.
","text":"swift is the smartest.","replyToPid":173475}
发表于 2019-8-9 10:57:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"F$&k that pos tire","replyToPid":0}
GMT+8, 2026-4-18 15:39 , Processed in 0.091488 second(s), 24 queries .
