查看: 76|回复: 5
Looking for job
 楼主| 发表于 2019-8-8 06:40:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any suggestions on a good trucking company or drop and hook company in central Michigan??   ","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-8-8 07:38:56 来自手机 | 显示全部楼层
542330 发表于 2019-08-07 23:23:56 Depends what you are looking for. The company I work for is a good company. Trucks none older then 3 years. Trailers none older then 5 years. Top pay for dry van. We don’t train so you need experience at least 6 months before they will even look at anyone.
","text":"I have 15 years experience with dry van, flatbed and reefer!  Just looking to make more than $1200 after driving 9000 miles in 3 weeks!","replyToPid":171919}
发表于 2019-8-8 07:23:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Depends what you are looking for. The company I work for is a good company. Trucks none older then 3 years. Trailers none older then 5 years. Top pay for dry van. We don’t train so you need experience at least 6 months before they will even look at anyone. ","replyToPid":0}
发表于 2019-8-8 08:49:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"You’ll make that easy with your experience you should be able get top starting pay like I did. Which would be over .50 a mile. \n\nGive me a call I’ll answer any questions that I can. Tell you the good and bad. I’m doing a 34 now and will start rolling around 0900 mountain time. So anytime after that would be a good time. \n\n256-786-2050\nMy name is Dale","replyToPid":0}
发表于 2019-8-8 09:56:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes look for a small company not a big company because you'll make way more with less demands","replyToPid":0}
发表于 2020-4-6 02:06:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Call Countryside Transportation in Sebewaing MI","replyToPid":0}
GMT+8, 2026-2-12 09:32 , Processed in 0.092614 second(s), 24 queries .
