查看: 152|回复: 6
As a truck driver, what is the biggest possible mistake you could make?
 楼主| 发表于 2019-8-8 03:49:04 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-8-8 05:40:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dropping a loaded trailer by not making sure your fifth wheel is secured before you pull out","replyToPid":0}
发表于 2019-8-8 05:36:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look down at your phone and then look up and a cars right there and you sped up and now can’t stop ","replyToPid":0}
发表于 2019-8-8 06:23:55 来自手机 | 显示全部楼层
625878 发表于 2019-08-07 21:49:46 This is another thing that shouldn’t have happened, it is called a tug test for a reason, then after moving about three feet  in 1st gear when starting then pull that trailer valve to verify it again.\n\nIf you don’t do a tug test and the trailer drops, this is all the drivers problem.
","text":"tug test and visual.  I had a trailer pass a tug test (albeit a light one) and when I checked with my flashlight the 5th wheel wasn't locked.  It can happen...","replyToPid":171836}
发表于 2019-8-8 14:01:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lose your CDL CLASS A License","replyToPid":0}
发表于 2019-8-8 18:30:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"forgeting to pop a lactate when you're lactose intolerant and eating a 3x3 in&out burger before you hit the road","replyToPid":0}
发表于 2019-8-8 18:45:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"falling asleep while driving","replyToPid":0}
GMT+8, 2026-2-8 02:17 , Processed in 0.078392 second(s), 24 queries .
