查看: 175|回复: 8
*sigh*
 楼主| 发表于 2019-8-8 03:29:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Welp,\nBeen driving since 3am, finally parked but picked up change instead of my keys when I got out & locked myself out. 🤦🏽‍♀️ & they key that was under my hood has mysteriously disappeared 😭 #HAPPYwednesday ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-8 15:43:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"I keep my spare in my wallet. it's good if you always carry your wallet with you","replyToPid":0}
 楼主| 发表于 2019-8-8 04:01:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had one zip tied under the hood, someone had to cut the tie and take it. Next time I’ll put it under the sleeper! Thanks ❤️","replyToPid":0}
发表于 2019-8-8 19:48:22 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"if you're driving a Freightliner, just ask another Freightliner driver to use his keys. The lock is so bad you can just jiggle it in and out quickly while turning and it'll probably open."}
发表于 2019-8-8 19:18:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Some zip tie can get brittle in the winter time so I use twist with to secure my spare underwear the sleeper","replyToPid":0}
发表于 2019-8-8 03:42:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hope it gets better. \n\nNext time keep your spare somewhere it has no chance of falling out. \n\nI used to keep mine wired up under the sleeper. \n\nBest of luck to you","replyToPid":0}
发表于 2019-8-8 16:00:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Or best bet is get a magnetic key box holder and attach it to ur frame of ur truck preferably inside the frame it won’t go anywhere then and nobody can see it ... All truckers or dumb people know what truckers do with their spares it’s either battery box or under hood or under cab ","replyToPid":0}
发表于 2019-8-8 20:06:31 来自手机 | 显示全部楼层
679939 发表于 2019-08-08 11:18:48 Some zip tie can get brittle in the winter time so I use twist with to secure my spare underwear the sleeper
","text":"*twist wire","replyToPid":172497}
发表于 2019-8-9 12:45:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"All brands of trucks theres only about 5 different types of keys.  So finding other drivers with same make an model first option. Most trucks unlock when you pull door handle on inside, top left corner of door frame easiest spot to slide a wire in to pull door handle. Third always leave window cracked, not where you can see it cracked but disengage the pressure off the seal makes it easier to slide wire or slinm Jim in to hit door lock.  and last dont use a zip tie to secure spare key, buy a hose clamp, more secure and you can use a coin if needs be to unscrew it.","replyToPid":0}
GMT+8, 2026-2-13 06:04 , Processed in 0.148793 second(s), 24 queries .
