查看: 258|回复: 10
First Time using this app.. how accurate is the info on weigh stations?? Should I trust them???
 楼主| 发表于 2019-8-8 02:12:40 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-8-8 02:21:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's as accurate as the truck driver that inputs the information or the scale house that uses the app to trick the status.","replyToPid":0}
发表于 2019-8-8 02:19:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I haven’t had an issue yet. It is updated by drivers though, so always check to see how long ago it was updated. ","replyToPid":0}
发表于 2019-8-8 02:34:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you see 3 straight reds, chances are they are actually closed however I think so DOT stations are messing with it. One time, on I-20 E, before AL, it was all red but the weigh station was open, I updated 'open' and right after my update it was changed to closed status","replyToPid":0}
发表于 2019-8-8 02:32:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"The scales in Love Ok are constantly being reported as closed they do alot of inspections their.( Dot trolling )","replyToPid":0}
 楼主| 发表于 2019-8-8 02:19:55 来自手机 | 显示全部楼层
742608 发表于 2019-08-07 18:19:04 I haven’t had an issue yet. It is updated by drivers though, so always check to see how long ago it was updated.
","text":"Thanks trouble ","replyToPid":171551}
发表于 2019-8-8 04:15:28 来自手机 | 显示全部楼层
679939 发表于 2019-08-07 18:34:18 If you see 3 straight reds, chances are they are actually closed however I think so DOT stations are messing with it. One time, on I-20 E, before AL, it was all red but the weigh station was open, I updated 'open' and right after my update it was changed to closed status
","text":"Fuçk it , keep updating! Nice job!","replyToPid":171573}
发表于 2019-8-8 04:12:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes, and please do the same , help others . \nSpread the words ","replyToPid":0}
发表于 2019-8-8 04:13:18 来自手机 | 显示全部楼层
766835 发表于 2019-08-07 18:21:21 It's as accurate as the truck driver that inputs the information or the scale house that uses the app to trick the status.
","text":"They are too stupid to do it lol","replyToPid":171559}
发表于 2019-8-8 07:50:51 来自手机 | 显示全部楼层
GMT+8, 2026-3-21 15:13 , Processed in 0.086354 second(s), 24 queries .
