查看: 91|回复: 8
How hard is it to do OTR?
 楼主| 发表于 2019-8-7 15:49:55 来自手机 | 显示全部楼层 |阅读模式
{"text":"If you can rate it from 1 to 5.  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-12 05:32:28 来自手机 | 显示全部楼层
发表于 2019-8-8 03:21:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends on how the dispatcher runs you. some places OTR means run the northeast because we make a lot of money.","replyToPid":0}
 楼主| 发表于 2019-8-12 05:29:45 来自手机 | 显示全部楼层
657069 发表于 2019-08-07 08:43:02 but of course, you have to be able to handle being away from home for long periods of time. You have to learn how to live in your truck. You have to learn how to like yourself cause you'll be alone a lot. If you cant do these very basic things, you cant do otr.
","text":"Got it. TY","replyToPid":170955}
发表于 2019-8-7 18:18:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Easiest job I ever had.","replyToPid":0}
 楼主| 发表于 2019-8-12 05:29:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"So easy then ","replyToPid":170953}
 楼主| 发表于 2019-8-12 05:30:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Motivates me. TY","replyToPid":171032}
 楼主| 发表于 2019-8-12 05:30:28 来自手机 | 显示全部楼层
646243 发表于 2019-08-07 19:21:11 depends on how the dispatcher runs you. some places OTR means run the northeast because we make a lot of money.
","text":"Will keep that in mind","replyToPid":171653}
发表于 2019-8-12 18:23:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤔🤔🤔🤔","replyToPid":0}
GMT+8, 2026-2-8 08:55 , Processed in 0.061201 second(s), 24 queries .
