查看: 293|回复: 9
Is this load is legal to carry on flat deck ?
 楼主| 发表于 2019-8-5 01:37:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1344.0,\"name\":\"\",\"url\":\"\",\"width\":756.0},{\"description\":\"\",\"height\":1104.0,\"name\":\"\",\"url\":\"\",\"width\":828.0}]","canComment":true}
发表于 2019-8-5 02:00:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"the little pipes inside may slide out during transprt. but its legal if it fits on the deck you just have to make sure nothing moves at all. i would personally pass on junk like that","replyToPid":0}
发表于 2019-8-5 01:54:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Never haul [a]nything unsafe, period!","replyToPid":0}
发表于 2019-8-5 02:42:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"you'd have to band each of those smaller pipes to the bigger ones,,something that is very time consuming for a shipper to do,,takes alot of banding to go length wise through the pipes,,I know I'd never haul it,unless it's banded properly","replyToPid":0}
发表于 2019-8-5 11:37:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"why don't u strap main set down . then pull small pipes out put dunnage on top of main stack then small pipe and strap those down. any thing not touched by straps and or secured to the trailer will result in out of service and a hefty fine by your local DOT officer 🤣🤣","replyToPid":0}
发表于 2019-8-5 01:53:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"😆  come on now","replyToPid":0}
发表于 2019-8-5 04:03:10 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"very risky to transport but its legal unless it doesn't move , need to secure the little pipes to avoid sliding"}
发表于 2019-8-5 19:30:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it’s unsafe don’t haul it.Not worth the risk.The sorry aśs shipper should have banded that properly.","replyToPid":0}
发表于 2019-8-5 20:59:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"wow,...... its technically no way to make that 100%  cop worthy- legal- weigh station legal-  ....... i would secure it best i could, BUT ONLY. after explaining and having the rate i was planned DOUBLED THE PRICE, then i would secure it best  i could, then TARP THE LOAD so no body could see what was under it, and the tarp would hold those very small ones from sliding out. and you have to drive accordingly, and baby the load to delivery....... cant drive like allot of these guys drive out there. that being said, you kinda got the shipper at your mercy here and CHARGE ACCORDINGLY ! ! ","replyToPid":0}
发表于 2019-8-5 21:09:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unsecure Load Citation","replyToPid":0}
GMT+8, 2026-3-21 14:17 , Processed in 0.086418 second(s), 24 queries .
