查看: 468|回复: 27
Why do people turn their hazard lights on during storms?
 楼主| 发表于 2019-8-4 06:15:06 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do we see if they are turning. LOL","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-4 08:29:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hazards in the rain are confusing. It's not turning that I worry about bug it looks like everyone is constantly braking. And then causes a chain reaction.   I think they are dangerous. ","replyToPid":0}
发表于 2019-8-4 14:47:53 来自手机 | 显示全部楼层
690887 发表于 2019-08-04 01:17:44 I mean STOP being the problem.  \n\nBefore the grammar police attack me.
","text":"Suggestion: you can edit your post with the 3 dots at the top right 👍","replyToPid":167429}
发表于 2019-8-4 09:10:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"You will get a ticket in Louisiana if caught doing this.","replyToPid":0}
发表于 2019-8-4 09:14:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hazard lights can actually reduce visibility making other drivers think you are stopped or stalled. They can make it difficult to tell if a driver is braking. STOP USING THEM WHILE IT'S RAINING.","replyToPid":0}
发表于 2019-8-4 10:05:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not supposed to it causes panic and if you run with them on no-one will realize the danger in front of you should there be one since you’ve been running them on the whole time...a cry wolf affect ","replyToPid":0}
发表于 2019-8-4 06:45:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I do when it gets bad.  it switches to turn when I hit the signal.  why wouldn't you give a heads up to those behind you?","replyToPid":0}
发表于 2019-8-4 07:32:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"somehow I just knew you were one of them\n raining riding in the left lane with your hazards on. retards","replyToPid":0}
 楼主| 发表于 2019-8-6 01:44:31 来自手机 | 显示全部楼层
690887 发表于 2019-08-04 01:16:46 If you need to turn your hazards on pull over an STOP on side of road.  Then turn hazards on.\n\nSTOP be the problem.
","text":"😎😎🙌","replyToPid":167428}
 楼主| 发表于 2019-8-6 01:44:14 来自手机 | 显示全部楼层
619622 发表于 2019-08-04 01:14:34 Hazard lights can actually reduce visibility making other drivers think you are stopped or stalled. They can make it difficult to tell if a driver is braking. STOP USING THEM WHILE IT'S RAINING.
","text":"AMEN TO THAT","replyToPid":167427}
 楼主| 发表于 2019-8-6 01:44:02 来自手机 | 显示全部楼层
741055 发表于 2019-08-04 01:10:24 You will get a ticket in Louisiana if caught doing this.
","text":"DIdnt know that. TY for the info","replyToPid":167423}
发表于 2019-8-4 09:16:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you need to turn your hazards on pull over an STOP on side of road.  Then turn hazards on.\n\nSTOP be the problem.","replyToPid":0}
发表于 2019-8-4 09:17:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I mean STOP being the problem.  \n\nBefore the grammar police attack me.","replyToPid":0}
发表于 2019-8-4 11:03:55 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"they put 4 ways on so we can't  tell when they are putting theybrakes on and run into them.\nno other reason"}
GMT+8, 2026-4-18 01:04 , Processed in 0.107840 second(s), 24 queries .
