查看: 85|回复: 6
T680 kw
 楼主| 发表于 2019-8-3 23:30:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey fellas just a quick question about the t680 2015. They do regem how often ? Couple times a week ? And they do when you driving or no ? If anyone know hit me up tsk 👊🏽","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-4 01:56:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Trucks regen while driving. You rarely do parked regen and they only need to if the filter is really bad where a normal regen while driving doesn’t clean it up enough. When you start needing to parked regen a couple of times a week you will need to get your filter to a dealer or someone that can do a burn to clean it. ","replyToPid":0}
发表于 2019-8-3 23:48:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"My last one was 6 weeks ago, & it only allowed parked regen.","replyToPid":0}
发表于 2019-8-3 23:58:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"the t680 is a truck....it can have different engines..what engine does your truck have?","replyToPid":0}
 楼主| 发表于 2019-8-5 07:48:10 来自手机 | 显示全部楼层
766319 发表于 2019-08-03 15:58:52 the t680 is a truck....it can have different engines..what engine does your truck have?
","text":"Cumming isx","replyToPid":166853}
 楼主| 发表于 2019-8-5 07:49:49 来自手机 | 显示全部楼层
","text":"Cummins isx","replyToPid":166853}
发表于 2019-8-5 18:04:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I run a Cummings ISX 15 and it dies a burn once every 2 days usually while driving. ","replyToPid":168162}
GMT+8, 2026-2-7 10:06 , Processed in 0.064051 second(s), 24 queries .
