查看: 192|回复: 4
eld compliance
 楼主| 发表于 2019-8-3 20:52:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have some questions on eld's being compliant and the hos.\n So I started this morning at 3:58am, it started raining bad so I parked it till the sun came up.  I was in sleeper berth for about an 1:45. Drove for 6 more hours.  Been in sleeper berth and off duty since about 1300, it's about 1936 and my eld says I still have 3 hours and 16 minutes left.  \n I'm doing a 34 so I don't need to drive how can this be right. Could I legally drive till 11 tonight. My day started at 4am. It's a Pedigree eld I just don't believe it's compliant the math doesn't add up unless I don't fully understand the hos, which could be I've been driving for a year.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0},{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true}
发表于 2019-8-3 20:57:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s the 8/2 split that has you confused. If you sit for 8 hours you get the rest of your drive time back that you haven’t used for that day.","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-8-5 21:19:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Learn how to drive in the rain 🤣, what are you going to do this winter, stay home?","replyToPid":0}
发表于 2019-8-4 14:34:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"depends on your day also... is it your 7 and 8th you could of gained","replyToPid":0}
发表于 2019-8-5 21:28:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"The 8/2 split initiated just as Arakos stated.","replyToPid":0}
GMT+8, 2026-4-18 12:07 , Processed in 0.129481 second(s), 24 queries .
