查看: 389|回复: 5
Walmart parking
 楼主| 发表于 2019-5-16 10:12:52 来自手机 | 显示全部楼层 |阅读模式
{"text":"Have ALL Walmart’s banned truck parking or select few? Can anyone help me out with this? I run along 64 & 75 every week, but my shut down times are usually late and all truck stops are filled. I need additional parking spots that are safe.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-16 23:42:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you have a SamsClub or Walmart card you're safe\nA few bad apples spoiled it for the rest of us unfortunately","replyToPid":0}
发表于 2019-5-17 02:28:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's always good to check with the Walmart Manager, In most cases it's not Walmart prohibiting Semi Trucks from parking but it's a city ordnance prohibiting and making it illegal to park there, Or it may be for a certain amount of time only. Which can be a very expensive thing, By getting a ticket or getting Towed, It doesn't matter if you are a customer or not. So I would check with the Manager he or she would know for sure. Hope it helps.","replyToPid":0}
发表于 2019-5-17 06:44:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any possibility of shutting down @ around 16:00?\n\nOthawise,\nfone 1st.","replyToPid":0}
发表于 2019-5-31 12:47:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Look at the satellite image of the Walmart you're wanting to park at. The parking spaces with white lines are for truck parking and you can also read the reviews on here for said Walmart and see if others have been able to park for their 10 hrs.","replyToPid":0}
发表于 2020-10-15 11:14:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"walmart in Williamsburg  and Berea Ky  is a major no no   you will be booted and it's like 600 to get it removed.  I 64 in dont know about","replyToPid":0}
GMT+8, 2026-4-16 14:31 , Processed in 1.603546 second(s), 24 queries .
