查看: 98|回复: 0
Problems with my Pete, dealer screwed me
 楼主| 发表于 2019-1-24 17:20:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"I bought a 06 Pete 387 with 840,000. The dealership I bought it from came highly recommend as good ppl and will work with you. I checked the truck over but like any truck there can be internal problems you can see or forsee. I had a 30 day warranty so iI fugure as I drive it I can make a list and have them fix it. Well first day out the gate did my first run I went to fuel the truck and found out my fuel sensing unit for broke and then 400 miles into my run the truck shutdown on me. They towed me in at no charged and fix the issue. They assured me they have thoroughly checked the truck and is in good working order. Week later it start to overheat fiund out there was 1 gallon of water in the radiator, so i bought 10 gallons of cat red. The truck still overheat so they sent it to the radiator shop, got it back. Then gauge cluster start going crazy. Truck was shaking and fellow drivers adviced me to ask them to do an alignment. At the end of the 30 days i returned the truck for the warranty maintenance. I got the truck back a week later. For a while I didnt have any issues. Then I was at the port and my clutch cable popped on me. Then a week later then my clutch goes out. Then days after that my fuel pump goes out. Then the synchronizer on my transmission goes out. Then just this week i replaced my kinpins,leaf springs and hangers, and shocks. All this in one year of having this truck.....","pics":"[]","canComment":true}
GMT+8, 2026-4-16 05:14 , Processed in 0.069679 second(s), 23 queries .
