查看: 191|回复: 8
wi/fi in truck
 楼主| 发表于 2019-8-1 01:36:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"Im wanting to get WiFi for my truck. anyone have any input as to who to use? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-8-1 08:49:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"IF your OTR get the Verizon JetPack.... if you have contract phone... it's only 20 bucks... if not... a little more","replyToPid":0}
发表于 2019-8-1 07:03:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Verizon hotspot ","replyToPid":0}
发表于 2019-8-1 04:11:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have mobile WiFi hotspot from Verizon. It works great for me can connect up to 12 devices to it. \n\nAs for which service to use go with your phone carrier. You can add it to your phone plan. Keep in mind where you drive mostly as it’s signal is based off cell phone towers. So if you have no phone service in that area you will not have WiFi either.  Like with Verizon Virginia and West Virginia  is bad but sprint is good. Montana and western states are mainly Verizon. ","replyToPid":0}
发表于 2019-8-1 09:45:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy a cheap straight talk phone and use it as a hotspot. Preferably a Motorola as they get the best signal. They use all towers and $55 a month gets you truly unlimited data.","replyToPid":0}
发表于 2019-8-1 07:08:25 来自手机 | 显示全部楼层
762568 发表于 2019-07-31 23:04:16 i have Verizon phone service so I will give them  a try. thank you I appreciate the info ..I drive the lower 48.
","text":"Then you know where you have good signal and that’s where you’ll have good WiFi. \n\nI don’t stream on it as I pay for data so I don’t get throttled. I game on it and have the 30 gb a month with roll over. With 2 iPhones everything sharing the 30 gb unlimited text and phone. My bill is 150 a month. ","replyToPid":163558}
 楼主| 发表于 2019-8-1 07:04:16 来自手机 | 显示全部楼层
542330 发表于 2019-07-31 20:11:01 I have mobile WiFi hotspot from Verizon. It works great for me can connect up to 12 devices to it. \n\nAs for which service to use go with your phone carrier. You can add it to your phone plan. Keep in mind where you drive mostly as it’s signal is based off cell phone towers. So if you have no phone service in that area you will not have WiFi either.  Like with Verizon Virginia and West Virginia  is bad but sprint is good. Montana and western states are mainly Verizon.
","text":"i have Verizon phone service so I will give them  a try. thank you I appreciate the info ..I drive the lower 48.","replyToPid":163333}
发表于 2019-8-1 10:41:09 来自手机 | 显示全部楼层
","text":"at&t","replyToPid":163333}
发表于 2019-8-1 13:21:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Verizon.","replyToPid":0}
GMT+8, 2026-2-6 13:02 , Processed in 0.058360 second(s), 24 queries .
