查看: 208|回复: 7
Anyone on here use the gold membership for turn by turn navigation. Is it worth the money and is it reliable
 楼主| 发表于 2019-7-31 23:24:42 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-8-13 08:01:24 来自手机 | 显示全部楼层
723808 发表于 2019-08-01 09:15:43 You exactly right it was my fault but I'm sure I'm not the only whose made a stupid  mistake.  I'm certainly doing more cross references now even pulling  the old atlas out.
","text":"When you get the dispatch put the address in Google Maps. Then switch to satellite view. Good habit to get in to.","replyToPid":164065}
发表于 2019-8-1 02:18:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used it for one day and didnt like it","replyToPid":0}
发表于 2019-8-1 00:09:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"No its not reliable but I personally like it and will continue to use it.  But at the same time I have my 780 Dezl going whoch is go to device, but there have been times I wished I would have followed the trucker path app especially  one time delivering to Walmart DC in ms and my garmin to behind the place in a field but had I followed the trucker path app I would of had no problem that the day I decided to go gold.","replyToPid":0}
发表于 2019-8-13 11:54:40 来自手机 | 显示全部楼层
489550 发表于 2019-08-13 00:01:24 When you get the dispatch put the address in Google Maps. Then switch to satellite view. Good habit to get in to.
","text":"All the time Cause dispatch a give you the wrong address, also make a habit out of looking at the address on the BOL, and see if everything comes together.  It save the headache of getting out of a bad mistake. ","replyToPid":178124}
发表于 2019-8-1 17:15:43 来自手机 | 显示全部楼层
762947 发表于 2019-08-01 08:39:22 Don’t blame Garmin cause you didn’t use common sense, and ended up behind the place that’s your fault.
","text":"You exactly right it was my fault but I'm sure I'm not the only whose made a stupid  mistake.  I'm certainly doing more cross references now even pulling  the old atlas out.","replyToPid":164044}
发表于 2019-8-1 16:39:22 来自手机 | 显示全部楼层
723808 发表于 2019-07-31 16:09:51 No its not reliable but I personally like it and will continue to use it.  But at the same time I have my 780 Dezl going whoch is go to device, but there have been times I wished I would have followed the trucker path app especially  one time delivering to Walmart DC in ms and my garmin to behind the place in a field but had I followed the trucker path app I would of had no problem that the day I decided to go gold.
","text":"Don’t blame Garmin cause you didn’t use common sense, and ended up behind the place that’s your fault.  ","replyToPid":162985}
发表于 2019-8-1 00:19:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"good to know. I've been wondering as well.","replyToPid":0}
GMT+8, 2026-4-18 15:38 , Processed in 0.101724 second(s), 24 queries .
