查看: 373|回复: 17
thanks Kansas dot.
 楼主| 发表于 2019-7-31 01:42:34 来自手机 | 显示全部楼层 |阅读模式
{"text":"had two lights go out in about an hour. I know they was on when I did my pre trip. geez. what's this deal about reflectors on mud flaps?  I see hardly any on trailers and a few on trucks. is this a new law?  or just one they use to add violations on?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-31 04:37:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just spoke with a freightliner mechanic being I’m sitting here waiting on my truck. He said it’s not the actual mad flap that needs the reflector it’s the bracket that holds the mud flap. That is fed law. ","replyToPid":0}
发表于 2019-7-31 01:46:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"You don’t need reflectors on mudflaps that I know of. Might be a new state law or like you said something to add violations on. I know your dot bar needs reflectors but not the mud flaps","replyToPid":0}
发表于 2019-8-4 09:52:49 来自手机 | 显示全部楼层
759874 发表于 2019-07-30 21:27:58 yeppers I'm a slacker apparently. LoL. the one I owned was 96. but this one is 06. could I just spray the whole deal with reflective spray paint?
","text":"No. Reason being... Paint washes off.","replyToPid":162033}
发表于 2019-7-31 06:42:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ya","replyToPid":162024}
发表于 2019-7-31 06:42:43 来自手机 | 显示全部楼层
542330 发表于 2019-07-30 20:37:09 Just spoke with a freightliner mechanic being I’m sitting here waiting on my truck. He said it’s not the actual mad flap that needs the reflector it’s the bracket that holds the mud flap. That is fed law.
","text":"ok that makes sense","replyToPid":161972}
 楼主| 发表于 2019-7-31 05:19:04 来自手机 | 显示全部楼层
","text":"ok thanks arakos","replyToPid":161972}
 楼主| 发表于 2019-7-31 01:48:33 来自手机 | 显示全部楼层
542330 发表于 2019-07-30 17:46:30 You don’t need reflectors on mudflaps that I know of. Might be a new state law or like you said something to add violations on. I know your dot bar needs reflectors but not the mud flaps
","text":"that's what I thought too. I guess my boss gonna have to finger that out. lol. good thing about not being o/o anymore.  still irritating as hell.","replyToPid":161769}
 楼主| 发表于 2019-7-31 05:35:15 来自手机 | 显示全部楼层
452168 发表于 2019-07-30 21:30:55 Knowing the government, they'll still find some other way to squeeze some cash out of you! Here's a good write up on it for those that want to learn more:\n\nhttp://sharplogger.vt.edu/documents/Conspicuity%20and%20reflector%20requirements%20393%2011.pdf
","text":"thanks Jimmy","replyToPid":162037}
发表于 2019-7-31 05:30:55 来自手机 | 显示全部楼层
","text":"Knowing the government, they'll still find some other way to squeeze some cash out of you! Here's a good write up on it for those that want to learn more:\n\nhttp://sharplogger.vt.edu/documents/Conspicuity%20and%20reflector%20requirements%20393%2011.pdf","replyToPid":162033}
 楼主| 发表于 2019-7-31 05:27:58 来自手机 | 显示全部楼层
452168 发表于 2019-07-30 21:24:03 Just put some conspicuity tape on the mudflap brackets if your truck is newer than a 97. This, including the trailer requirements have been in effect for over two decades now.
","text":"yeppers I'm a slacker apparently. LoL. the one I owned was 96. but this one is 06. could I just spray the whole deal with reflective spray paint?","replyToPid":162029}
发表于 2019-7-31 03:07:05 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I never thought about it until you mentioned it, but looking around here, every truck had reflectors on their mud flaps... I would guess it is required. "}
 楼主| 发表于 2019-7-31 05:21:10 来自手机 | 显示全部楼层
599477 发表于 2019-07-30 19:07:05 I never thought about it until you mentioned it, but looking around here, every truck had reflectors on their mud flaps... I would guess it is required.
","text":"thanks jazzy. good to know","replyToPid":161867}
发表于 2019-7-31 05:24:03 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Just put some conspicuity tape on the mudflap brackets if your truck is newer than a 97. This, including the trailer requirements have been in effect for over two decades now."}
GMT+8, 2026-4-18 02:52 , Processed in 0.081871 second(s), 24 queries .
