查看: 137|回复: 8
Qualcomm navigation
 楼主| 发表于 2019-7-30 23:01:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"anybody use their Qualcomm's built in navigation? is it any good? I've been getting by just fine with Google it avoids the toll roads and I just use my brain and my eyes if I see a low clearance sign or a sign that says no trucks","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-31 01:44:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"You will get yourself in trouble using google as it is not truck routing. The built in Qualcomm one is jb hunt system and heard it’s bad as it freezes up on you. Honestly best way is a good ole rand map aside from that an actual trucker gps. ","replyToPid":0}
发表于 2019-7-31 03:21:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Any GPS you use double check the route to avoid going through cities or county roads, where you could end up somewhere where you are not supposed to take a big rig through...","replyToPid":0}
发表于 2019-7-31 15:00:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"To answer your question, yes, use the Qualcomm for now. The Qualcomm (If it uses Navigo or Co Pilot) is the safest tool available to you until you get a proper truck GPS. ","replyToPid":0}
发表于 2019-7-31 03:14:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Qualcomm routing is the trucking version of the original Apple maps. ","replyToPid":0}
发表于 2019-7-31 03:27:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use the Qualcomm but not necessarily the route it gives.  will map it out then put in routing points to change it to the route I want.  I also like the way it says Mississippi lol.","replyToPid":0}
发表于 2019-7-31 05:28:52 来自手机 | 显示全部楼层
602062 发表于 2019-07-30 19:21:40 Any GPS you use double check the route to avoid going through cities or county roads, where you could end up somewhere where you are not supposed to take a big rig through...
","text":"Exactly ","replyToPid":161883}
发表于 2019-7-31 06:50:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Qualcomm is horrible","replyToPid":0}
发表于 2019-8-5 21:39:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use Qualcomm for open road, but I double check the route against Google maps over the last ten miles.","replyToPid":0}
GMT+8, 2026-4-18 12:15 , Processed in 0.149788 second(s), 24 queries .
