查看: 449|回复: 20
A Great App
 楼主| 发表于 2019-7-30 04:13:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"I know, I'm behind on these apps, but I just started using this weigh app ...and what a time saver.  I pulled over the scales put in my scale number, paid  all from my phone, pulled off the scales and out of the way, reset my trailer wheels and got back to rolling.  Absolutely loved it.\n","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1080.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true}
发表于 2019-7-30 11:10:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes sir the dot scale is the end of story.\n\nalso if you need a printed copy, the app emails it to you. simply print it on your printer.\n\ndon't tell me you don't have a printer in the truck. it's an essential piece of equipment unlike the Xboxes that drivers have today.","replyToPid":0}
发表于 2019-7-30 04:58:02 来自手机 | 显示全部楼层
发表于 2019-7-30 07:34:37 来自手机 | 显示全部楼层
发表于 2019-7-30 04:54:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes but if you are close you still need to go inside and get the ticket. Several weigh stations won’t look at your phone they want the actual scale ticket. ","replyToPid":0}
回复 支持 0 反对 3
 楼主| 发表于 2019-7-30 11:22:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good info Caeli!  I don't have a printer right now in my truck.  I pretty much use transflo but its  high on the list especially before I get my own authority","replyToPid":0}
 楼主| 发表于 2019-7-30 08:42:45 来自手机 | 显示全部楼层
723808 发表于 2019-07-30 00:33:39 Arakos if I was close I would have went in and got the ticket, no doubt.  But Shooting down to Dallas crossing thru Oklahoma and I just wanted to make sure my weight wasn't over or even close.  Tks for the reply
","text":"I also wanted to say my experience the scales are going to be over some to cover their behinds for they know they can be held liable in a court of law.  But the DOT don't give crap about your scale ticket its their scales all they care about.  But you can find a officers that will cut you a break.  Its how you cunduct yourself.","replyToPid":160963}
发表于 2019-7-30 07:31:22 来自手机 | 显示全部楼层
542330 发表于 2019-07-29 21:06:13 I’ve been given the ok to go because of cat scale ticket 2 times. Once at scale house on i90 Spokane Washington and Nebraska scale house us2. Their scale said I was overweight shown them cat scale ticket they let me go.
","text":"Lunch counter bs.","replyToPid":160566}
发表于 2019-7-30 05:06:13 来自手机 | 显示全部楼层
662769 发表于 2019-07-29 20:58:02 Weight Stations dont care about CAT Scale tickets. Their scale is the end all be all.
","text":"I’ve been given the ok to go because of cat scale ticket 2 times. Once at scale house on i90 Spokane Washington and Nebraska scale house us2. Their scale said I was overweight shown them cat scale ticket they let me go. ","replyToPid":160527}
发表于 2019-7-30 06:46:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"You'll find a couple of locations where the data service just isn't good enough to use it, depending on your cell phone plan. I pull on the scales and crank up the app, only to sit and watch the spinning circle of death for a few moments and reaching over to hit the button and do it the old fashioned way. I have Verizon and it's happened a couple of times but the one that comes to mind because it's happened more than once is the Petro in Oak Grove Mo.","replyToPid":0}
发表于 2019-8-3 12:05:47 来自手机 | 显示全部楼层
","text":"🤣🤣🤣🤣that’s like calling a city cop on the feds 🤣🤣🤣🤣🤣","replyToPid":160527}
发表于 2019-7-30 08:20:22 来自手机 | 显示全部楼层
662769 发表于 2019-07-29 23:34:37 I'm not going to says he's lying but I'm not saying I believe it either.
","text":"Oh it’s true I’ll never forget the Nebraska one as I just went through a blizzard and had a shitload of snow/ice pack all over my trailer and he told me to go and clear that. After an hour of banging all over the trailer underneath and back doors I went in to see if that was good enough he said go ahead and go. When I 1st went there and scaled I was way over as the load I had was 44k was so I was close to max gross. He told me I was over weight I told him no way I just scaled the load at cat scale and he asked to see my scale ticket. Shown him and he said ok that snow on your trailer is what’s making you over and to remove it. ","replyToPid":160886}
发表于 2019-7-30 08:23:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh it’s true I’ll never forget the Nebraska one as I just went through a blizzard and was over because of snow pack on the trailer. He wanted to see my scale ticket after I told the guy I just scaled and was legal. He told me to remove the snow so I was out there hitting the trailer with my tire knocker knocking it off. Went back inside he said I saw you working to remove the snow to just go on and go. ","replyToPid":0}
发表于 2019-7-30 08:24:47 来自手机 | 显示全部楼层
75795 发表于 2019-07-29 22:46:07 You'll find a couple of locations where the data service just isn't good enough to use it, depending on your cell phone plan. I pull on the scales and crank up the app, only to sit and watch the spinning circle of death for a few moments and reaching over to hit the button and do it the old fashioned way. I have Verizon and it's happened a couple of times but the one that comes to mind because it's happened more than once is the Petro in Oak Grove Mo.
","text":"I also figured out that if you swipe everything closed and restart the app it helps at times. ","replyToPid":160791}
GMT+8, 2026-4-18 02:50 , Processed in 0.122673 second(s), 24 queries .
