查看: 191|回复: 9
trip planning
 楼主| 发表于 2019-7-30 02:23:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"what are the top 5 details to consider when planning your trip?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-30 07:39:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"1 Check weather\n2 Choose route\n3 Plan fuel stops\n4 Get to truckstops by 4-5pm\n5 Have contact info for both ends","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-7-30 09:28:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Prior to heavy haul\n\nMy main concerns were:\n\nReceivers contact info\nariel view of delivery location, entrances, possible hazards from freeway to location.\nWhat major cities would I hit, and would I hit them near rush hour.\nis reciever first come first serve or strictly appt.  <-- set travel time on strick appt to not arrive overly early an waste clock.\nIf on east coast only run super early mornings to avoid most traffic, an find parking at end of day.","replyToPid":0}
发表于 2019-7-30 08:55:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your so full of SH!T skip 5. go to 2. \nwhy would you check the weather it changes constantly.\nDo you know the road construction speed limits or traffic or detours or if an accident causes closures or you are at a dead stop, So why are you spinning your wheels, Waisting time. \nGet to the truck stop by 4-5 pm So you are a 8 hour driver. 8 on and 16 off that explains it all. You get up start really early \nYou set your route find a destination that you set as your goal to accomplish, And run it, Take your 30 after 3 hrs or when ever time after that, When you get down to no less than a quarter of a tank you find and set your desired fuel stop, Fill up and keep it moving, If you need to make adjustments along the way to compensate for time loss, Do so ending as close to your 11 hrs. early so parking is not an issue. You must be a Rookie","replyToPid":0}
发表于 2019-7-30 08:33:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Breakfast \nLunch \nSnack\nDinner\nIce Cream","replyToPid":0}
发表于 2019-7-30 08:09:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"On point with all you mentioned,great informative info respects Landstar ","replyToPid":0}
发表于 2019-7-30 07:42:01 来自手机 | 显示全部楼层
发表于 2019-7-30 08:36:22 来自手机 | 显示全部楼层
662769 发表于 2019-07-29 23:42:01 Beer\nWeed\nWhiskey \nFeed\nSpeed
","text":"Don’t forget pants","replyToPid":160898}
发表于 2019-7-30 09:19:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Consideration of type of trailer an freight your hauling also impacts these choices. \n\nMine: \nSunrise/sunset times\nContact info on receiving end\nAll permits, and good understanding of routing listed on them. Including major cities with travel curfews an estimated time I will hit them.\ngeneral idea of weather conditions (more so if headed to snow zone or towards known hurricane)\ntrain tracks","replyToPid":0}
发表于 2019-7-30 17:47:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"First what you going to eat during the day. \nSecond make the drive a enjoyable \nThird find some interesting knowledge things to listen to \nFourth always look for parking spots as you drive \nFilth have fun ","replyToPid":0}
GMT+8, 2026-4-18 13:58 , Processed in 0.085688 second(s), 24 queries .
