查看: 258|回复: 10
Does DOT require a ViN number?
 楼主| 发表于 2019-7-29 09:09:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"Someone told me today, I need to have the last eight digits of my VIN number visible on the side of my truck.  Does anyone know if this it true and what States requires it? tks","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-29 09:23:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes it is true if you run Colorado.   Put the last 8 of or vin on passenger side so they can easily see it...  ","replyToPid":0}
发表于 2019-8-1 09:31:45 来自手机 | 显示全部楼层
270970 发表于 2019-07-29 03:08:49 Just had one done.  Last 8  of vin and both sides in Iowa and must be able to read from 50 feet away.
","text":"really when did Iowa start an not bein smart but your the first iv heard say this","replyToPid":159537}
发表于 2019-7-29 22:08:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s NOT required just makes your life a little bit easier and keep you rolling. Just Colorado is the only one that puts it in their computer every pass through. If you do not have your last 8 of vin on passenger side they will make you go in with paperwork so they can put it in the computer. I still see trucks with it on a piece of cardboard in the passenger window. ","replyToPid":0}
发表于 2019-7-29 11:08:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just had one done.  Last 8  of vin and both sides in Iowa and must be able to read from 50 feet away.","replyToPid":0}
发表于 2019-7-29 10:53:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"only in Colorado thier the only state that wants like that an no it not a fmcsa rule an no you dont have to put it on if you dont then when you come into the scale house in Colorado they just have you bring your paper work in nothing big i got my vin on an most the time i still have to bring my paper work in","replyToPid":0}
 楼主| 发表于 2019-7-29 10:17:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hear not having your vin number is a good way to get a level 1 inspection.","replyToPid":0}
发表于 2019-7-29 10:09:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's not required by the FMCSA but certain states might. I know none of the states that I run need it.","replyToPid":0}
发表于 2019-7-29 09:55:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes only Colorado.  Last 8 passenger side only.. not sure about Alaska but you should be good to go in all the others... ","replyToPid":0}
 楼主| 发表于 2019-7-29 09:47:07 来自手机 | 显示全部楼层
663650 发表于 2019-07-29 01:23:37 Yes it is true if you run Colorado.   Put the last 8 of or vin on passenger side so they can easily see it...
","text":"Thanks parknlott, is that only on Colorado?","replyToPid":159328}
GMT+8, 2026-4-17 19:54 , Processed in 0.115435 second(s), 24 queries .
