查看: 149|回复: 11
Truck invertor
 楼主| 发表于 2019-7-28 05:17:21 来自手机 | 显示全部楼层 |阅读模式
{"text":"Need some Input from you guys. No APU in new truck. What size inverter do I need for a TV/PS4, frig, microwave and cpap? Noting microwave/cpap will only be plugged in per use when TV/PS4 is off.  Any preferred models? Buying off Amazon not at truck stop. Thanks.","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-28 05:32:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"The ones at pilot are actually good I’d say at least 2500","replyToPid":0}
发表于 2019-7-28 09:43:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"a 1500 will work perfectly","replyToPid":158118}
发表于 2019-7-28 05:58:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Google says PS4 wattage consumption is around 150 and TV will be around 70 depending on model. The microwave I have says 900 watts but when I run it my inverter says it’s consuming about 1250. So like Arakos said 2500 will probably be sufficient. ","replyToPid":0}
发表于 2019-7-28 06:40:03 来自手机 | 显示全部楼层
631176 发表于 2019-07-27 21:58:04 Google says PS4 wattage consumption is around 150 and TV will be around 70 depending on model. The microwave I have says 900 watts but when I run it my inverter says it’s consuming about 1250. So like Arakos said 2500 will probably be sufficient.
","text":"🙄","replyToPid":158054}
发表于 2019-7-28 11:39:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Figure out the wattage that you’re going to be drawing and double it. I’ve had good luck with the centech inverters from harbor freight. I would go with a 2000 or 2500 watt with what you are doing. The biggest thing is to make sure that the wires powering the inverter are sufficient. ","replyToPid":0}
发表于 2019-7-28 12:31:02 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you like to run a cb look into a pure sine wave so you don't get interference. I run a 3000 watt inverter and it runs everything I've needed it for."}
发表于 2019-7-28 18:10:59 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I have everything that you listed and have a 1800 watt inverter company installed with APU. I haven't had any issues, so I would recommend at least this. If I were buying myself I would go probably a 2500, professionally installed."}
发表于 2019-7-29 02:49:17 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Cooper bussman 1800 watt pure sine "}
 楼主| 发表于 2019-7-29 08:55:47 来自手机 | 显示全部楼层
687587 发表于 2019-07-28 03:39:11 Figure out the wattage that you’re going to be drawing and double it. I’ve had good luck with the centech inverters from harbor freight. I would go with a 2000 or 2500 watt with what you are doing. The biggest thing is to make sure that the wires powering the inverter are sufficient.
","text":"👍","replyToPid":158442}
GMT+8, 2026-2-6 04:28 , Processed in 0.096881 second(s), 24 queries .
