查看: 218|回复: 6
Pre pass problem
 楼主| 发表于 2019-7-27 08:30:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just changed the batteries and I still don’t get in cab direction at weigh stations. Am I do something wrong here?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-27 08:45:15 来自手机 | 显示全部楼层
回复 支持 4 反对 1
发表于 2019-7-27 22:42:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"you look like one of the ANTIFA Ho Mos, Or is your hair just that dirty.","replyToPid":0}
 楼主| 发表于 2019-7-27 09:36:44 来自手机 | 显示全部楼层
662769 发表于 2019-07-27 00:45:15 Defective transponder. I had same thing happen.
","text":"Ugh lame ","replyToPid":157078}
发表于 2019-7-28 00:40:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"YOU ARE ONE UGLY CHICK 😱😱🤢🤢🤢🤮🤮🤮","replyToPid":0}
发表于 2019-7-27 20:22:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Give them a call same thing happened to me with in 24 it was working again only had problem with prepass plus ","replyToPid":0}
发表于 2019-7-28 00:38:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"you are 🤣😂😂","replyToPid":157099}
GMT+8, 2026-4-18 12:15 , Processed in 0.085811 second(s), 24 queries .
