查看: 515|回复: 23
Four Super Singles Vs Eight Drive Tires
 楼主| 发表于 2019-7-26 09:13:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a friend wanting to sell me his almost new super singles Michelins off his truck that he's now parting out.  The tires are like new.   I have never been a fan of super singles BUT for the low price I am considering it.  Looking for advice from experience operators thanks?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-26 09:20:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are thinking on just putting them on your truck you will need new axles.\n\nPersonally I hate super singles because if you blo just one you gotta stop. Where you blo one when you have 8 you can keep rolling to a shop instead of paying for a road call. ","replyToPid":0}
回复 支持 6 反对 1
发表于 2019-7-26 11:51:27 来自手机 | 显示全部楼层
542330 发表于 2019-07-26 01:20:32 If you are thinking on just putting them on your truck you will need new axles.\n\nPersonally I hate super singles because if you blo just one you gotta stop. Where you blo one when you have 8 you can keep rolling to a shop instead of paying for a road call.
","text":"don't forget the new wheel you'll have to buy too. \n\nask me how I know.","replyToPid":156306}
 楼主| 发表于 2019-7-26 18:23:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks Jazzy, my friend is wanting to sell me 5 tire n wheels 1500..  Its tempting but I must give 4 of mine to him.  I think, I will keep mine after reading the post.  I don't need another set until about two months running and than buy the M710 Bridgestones to ncreae my gas mileage.  Thanks for your comment.","replyToPid":0}
发表于 2019-7-26 21:58:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like them never had a issue as far as traction goes if you got good tread it’s good of not it’s not fun. ","replyToPid":0}
发表于 2019-7-26 09:29:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"why would he change axles? if the trucks being parted out they should be on wheels. bolt on and go.\n\nI wouldn't run super singles for the same reason blow one and your done not to mention as soon as the wheel hits the ground it's usually garbage too.","replyToPid":0}
发表于 2019-7-26 09:20:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are thinking on just putting them on your truck you will need new axles.\n\nPersonally I hate super singles because if you blow just one you gotta stop. Where you blow one when you have 8 you can keep rolling to a shop instead of paying for a road call. ","replyToPid":0}
 楼主| 发表于 2019-7-29 08:52:33 来自手机 | 显示全部楼层
452168 发表于 2019-07-28 16:51:53 Not worth it, driver. When you lose a tire the wheel usually gets damaged too unless you get pulled over in time. With duals you can limp to get it repaired much cheaper (both monetarily and time-wise) versus sitting on the side of the road getting raped by the hour.
","text":"i tell you I'm totally convinced to bite the bullet and keep mine n buy 8 new drives.  Luckily, I don't need them until couple more months","replyToPid":158819}
 楼主| 发表于 2019-7-28 11:42:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's a good way to put it lol.","replyToPid":158383}
发表于 2019-7-28 10:26:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"super singles Su@kass","replyToPid":0}
发表于 2019-7-26 22:21:20 来自手机 | 显示全部楼层
610123 发表于 2019-07-26 02:54:17 you don't need new axles to put super singles on however if you go the other way, back to duals on a truck that was ordered with a super singles set up, sometimes those have wider axles that you can't put duals on.
","text":"Correct you are ....you do not have to change the axles","replyToPid":156388}
 楼主| 发表于 2019-7-26 09:44:24 来自手机 | 显示全部楼层
","text":"That's certainly something to think about.  It does seem like I'm seeing more super singles on the road.","replyToPid":156306}
发表于 2019-7-26 10:54:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"you don't need new axles to put super singles on however if you go the other way, back to duals on a truck that was ordered with a super singles set up, sometimes those have wider axles that you can't put duals on.","replyToPid":0}
发表于 2019-7-26 12:01:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can just bolt them right on. yes you do save in weight.  But you blow a tire where are you going to be? on the side of the road waiting on road service and paying a bill that's twice as much than if you blew one of you 8 drives and limped it to a shop. oh yea and they dont get good traction so if you do any winter weather driving you may as well park it til the storm is over. personal I wouldnt put them on my truck or my trailer.","replyToPid":0}
发表于 2019-7-26 12:07:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"For me duals for two reasons; if I have one flat tire, I can drive to a nearby shop and any tire shop can work on them","replyToPid":0}
发表于 2019-7-26 13:16:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"I paid $3000 to switch to super singles on my last truck (wheels and tires). I hated them. Not for winter at all. No options for winter tires either. ","replyToPid":0}
GMT+8, 2026-4-17 23:34 , Processed in 0.091182 second(s), 24 queries .
