查看: 251|回复: 13
Team driver
 楼主| 发表于 2019-7-26 05:20:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"What is a good procedure to try to find someone to team with? I believe you’ve got to have similar work ethic and at least be civil to make it work.\n Any other suggestions on where to look for a team driver and go from there?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-26 08:58:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get married. Then you can plow your coworker. ","replyToPid":0}
发表于 2019-7-26 13:22:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"A lot of similarities will probably be best. Similar home location, similar political views, music preferences, shower preferences, cleanliness level, food choices, etc","replyToPid":0}
发表于 2019-7-26 09:16:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I also will never team, It doesn't work out for most drivers, It's too small of space and too much time spent in the Tractor for two drivers.","replyToPid":0}
发表于 2019-7-26 06:38:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ll never team again. But best way is talking to the person. ","replyToPid":0}
发表于 2019-7-26 09:08:43 来自手机 | 显示全部楼层
366847 发表于 2019-07-26 00:58:56 Get married. Then you can plow your coworker.
","text":"LMFAO","replyToPid":156283}
发表于 2019-7-26 09:16:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s very hard your close with the Work Ethics and you have you get along very very Well it’s tough ","replyToPid":0}
发表于 2019-7-26 09:17:28 来自手机 | 显示全部楼层
","text":"Right and that will get old and it will be a Divorce and you will have to Cut the Truck in Half 😂😂😂😂😭🤣💀","replyToPid":156283}
发表于 2019-7-26 09:21:07 来自手机 | 显示全部楼层
发表于 2019-7-26 09:34:55 来自手机 | 显示全部楼层
662769 发表于 2019-07-26 01:21:07 ˙p∀ ǝƃɐdʞɔɐq ɐ ʎɹ┴
","text":"lol you can't be taken seriously upside down like that.  LMFAO","replyToPid":156308}
GMT+8, 2026-4-16 16:28 , Processed in 2.238619 second(s), 24 queries .
