查看: 97|回复: 0
volvo timing
 楼主| 发表于 2019-1-24 16:38:07 来自手机 | 显示全部楼层 |阅读模式
{"text":"Help needed,i am working on a volvo D16 the cylinder head was crack,i have change the cylinder head,the problem i have ,there is no timing mark on the flywheel, i turn the engine manually and i insert a rod in number cylinder and bring # 1 piston to the top,but when i start the engine i am getting a clicking sound, my question is, when i bring # 1 piston to the TDC would be when the piston stop move or when it about to move down,thank you all for any help,","pics":"[]","canComment":true}
GMT+8, 2026-3-21 10:08 , Processed in 0.062408 second(s), 23 queries .
