查看: 194|回复: 5
This Dock Will Test your Backing Skills
 楼主| 发表于 2019-7-25 23:24:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"No Room For Error ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1512.0}]","canComment":true}
发表于 2019-7-26 00:01:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"That is easy going just backing in straight. Try to back in this doc with 90 degrees that’s different level then ;)","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-7-26 00:08:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks like you did an awesome job! 👍","replyToPid":0}
发表于 2019-7-26 01:13:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Good job man👍","replyToPid":0}
发表于 2019-7-26 01:21:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"nice","replyToPid":0}
 楼主| 发表于 2019-7-26 13:08:17 来自手机 | 显示全部楼层
655466 发表于 2019-07-25 16:01:52 That is easy going just backing in straight. Try to back in this doc with 90 degrees that’s different level then ;)
","text":"it was a 90 this place was really small 🚚","replyToPid":155802}
GMT+8, 2026-4-17 22:25 , Processed in 0.117198 second(s), 24 queries .
