查看: 122|回复: 9
30 minute rest break
 楼主| 发表于 2019-7-25 07:31:48 来自手机 | 显示全部楼层 |阅读模式
{"text":"The first time taking a 30 minute break.....i fell fast asleep😂😂......ended up 3 hours late.....","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-25 07:39:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yikes. That’s happened to me a couple times. At least you got some much needed rest 😁","replyToPid":0}
发表于 2019-7-25 11:04:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Rookie!!!","replyToPid":0}
发表于 2019-7-25 09:20:40 来自手机 | 显示全部楼层
发表于 2019-7-25 10:00:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your body needed the rest.  Better late than dead on the side of the road from falling asleep.","replyToPid":0}
 楼主| 发表于 2019-7-25 07:46:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes indeed.....that was the first time.......and I was only an hour away......crucial","replyToPid":0}
发表于 2019-7-25 09:10:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Did you forgot to set the alarm or slept through it? I've heard the screaming meanies are louder than anything ","replyToPid":0}
发表于 2019-7-25 10:01:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dammit 🤣","replyToPid":0}
发表于 2019-7-25 12:25:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Screamin meanie is hands down the best alarm. When I need to wake up at a certain time I set my alarm on my phone. If it’s less then my normal 6 hours I also put my screamin meanie on. ","replyToPid":0}
发表于 2019-7-25 17:27:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"🤣🤣","replyToPid":0}
GMT+8, 2026-2-5 18:49 , Processed in 0.080416 second(s), 24 queries .
