查看: 182|回复: 1
Replacing fuel tank strap liner on KW T600?
 楼主| 发表于 2019-1-24 16:32:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone know of the best way to replace these strap liner pieces? I have one for sure bad. My T600 has 4 fuel tanks. For a total of 475 gallons, and driver tank needs the new rubber for sure.\nPete","pics":"[]","canComment":true}
发表于 2019-2-20 07:11:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I recently replaced mines on my t660 with a car jack to lift up the tank and replace the rubber piece in the bottom, loosened up the nut with a power gun and heat, I didn’t want to break it. Super simple 10 minutes tops","replyToPid":0}
GMT+8, 2026-3-21 07:55 , Processed in 0.064771 second(s), 23 queries .
