查看: 195|回复: 5
PFJ points
 楼主| 发表于 2019-7-23 08:41:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"how do I use the points at pilot flying j? specifically can i use them to buy a GPS and if so how many points equal 1 dollar amount?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-23 09:46:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"One point is a cent. So 100pts is a dollar. You can use the points for pretty much anything outside of tobacco products and alcohol. Just have them scan the barcode on your app and you can redeem them. ","replyToPid":0}
发表于 2019-7-23 10:34:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can even use them for laundry and parking. that's what I mostly use them for. except when I save them for big ticket items.\n\ndepending on your plan you can get multiple points per gallon. I get 5 points per gallon. but when they ran that double points program for using mobile fueling I got 10 pts per gallon. adds up quick that way","replyToPid":0}
发表于 2019-7-23 09:56:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can also swipe your pfj card or use your phone number on the pin pad. ","replyToPid":0}
 楼主| 发表于 2019-7-23 09:25:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"why are you even on ?","replyToPid":153278}
发表于 2019-7-23 09:36:42 来自手机 | 显示全部楼层
GMT+8, 2026-4-18 10:41 , Processed in 0.070569 second(s), 24 queries .
